Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 32
Thread: Amp Shock....HELP, please.
  1. #11
    Falls Church, VA
    Quote Originally Posted by robozapian
    I think it might be overheating within seconds, could it be a temperature sensor is shot?(is there even such thing?)
    nah, not really
  2. #12
    Falls Church, VA
    nah, not really
  3. #13
    _
    Mar 2004
    Little Elm, Texas
    no temp sensor, but the protection circut will essentially do teh same thing.
    most any decent amp on the market will have protection built in.
    Honnestly, if it doesn't, it's crap.
    In fact, i'd be willing to say that instead of saying
    good amp, because of the protection circuitry.
    I'd rather say:
    if it doesn't have protection circuitry, it's a crappy amp.
    if you can make the distinction there.
    i'd venture to bet that, as the others have said, there's something internal that's no longer making a solid connection.
    check all of the solder joints (this COULD take a while).
    Jan Bennett
  4. #14
    Mar 2006
    I opened it up......and found that theres a half inch long, millimeter wide black charred gouge thing. Is there any way to fix that?
  5. #15
    Feb 2006
    Pics? Even better; in focus pics. IE, use the macro setting when taking close-ups of circuit boards... Not sure I recall ever seeing a 'gouge thing' inside an amp.
  6. #16
    _
    Mar 2004
    Little Elm, Texas
    oooo
    PICS!
    this thread is useless without pics!!
    where's that smiley.....
    Jan Bennett
  7. #17
    Feb 2006
    Quote Originally Posted by Red GTi VR6
    In fact, i'd be willing to say that instead of saying ...
    I'd rather say:
    Taken out of context; he said his amp was broken. by saying "good amp" I meant 'not broken'.
    Legacy amps have protection circuitry, but I recall someone saying Lecacy is crap.
  8. #18
    Mar 2006
    Heres the picture of it.
  9. #19
    Maximum Bitrate 3onDubs's Avatar
    Aug 2005
    Anaheim Hills, Ca
    ooooo...don't know if that's fixable...anyone else??
    PostCount++
    - SrCsTc's Bezel
    - Alpine W200/H701
    - ED Nine.2X
    - OZ Matrix Elites
    - ED Nine.1
    - Idmax 12's
  10. #20
    Feb 2006
    It looks as though someone has already repaired part of it using that red wire as a jumper, there is still one trace that is damaged and would need the same treatment. There is one solder point at the bottom of the pic, if there is another one (can't see from the pic), then you could do the same with that.
  1. PC Motherboard to 1 amp or 2?
    By hanzacra in forum General Hardware Discussion
    Last Post: 11-27-2007, 03:41 AM
  2. Hard drive shock / vibration thoughts
    By S11D336B in forum General Hardware Discussion
    Last Post: 09-27-2006, 12:40 AM
  3. Amp running hot...??
    By Emerica2843 in forum General Hardware Discussion
    Last Post: 02-08-2006, 06:40 PM
  4. Amp running hot...??
    By Emerica2843 in forum Car Audio
    Last Post: 01-29-2006, 08:29 PM
  5. vw mk4 monson amp and another amp
    By colorless in forum Car Audio
    Last Post: 10-03-2005, 01:32 PM
