Page 1 of 4 1234 LastLast
Results 1 to 10 of 32
Thread: Amp Shock....HELP, please.
    Mar 2006
    Exclamation Amp Shock....HELP, please.
    Hey, I had a setup in my car with just one 4 channel amp.
    I went to new york and my cuz gave me his old amp that he said was broken. I hooked it up for the hell of it when I got home, it worked!! But...
    Even the slightest shock turns it to protect mode for a few seconds. This makes it unuseable obviously.
    What can be causing this, and how can I fix it? it sounds much better then the amp I have now(when it doesnt turn off and on).
    Thanx.
    P.S. It is a Kicker Impulse 352xi amp, if anyone needs that to answer the question.
    Feb 2006
    CAn you define "shock".
    Are you talking electrical shock or bumps/tapping or what?
    Gonna have to assume you mean bumps and probably means something is loose and grounding out against something it shouldn't be touching. Could be anything. If you get it solved, it'll probably be a good amp, because of the protection circuitry.
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    i'd say tear it open and check for any loose components, maybe there is a badly soldered lead
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    Maximum Bitrate 3onDubs's Avatar
    Aug 2005
    Anaheim Hills, Ca
    Opener up
    PostCount++
    - SrCsTc's Bezel
    - Alpine W200/H701
    - ED Nine.2X
    - OZ Matrix Elites
    - ED Nine.1
    - Idmax 12's
    Mar 2006
    K, im heading to vball game, then I will open it up again, didnt see anything the first time i checked tho.
    Aug 2005
    Anaheim Hills, Ca
    Shaker around and see if anything is loose
    PostCount++
    - SrCsTc's Bezel
    - Alpine W200/H701
    - ED Nine.2X
    - OZ Matrix Elites
    - ED Nine.1
    - Idmax 12's
    Falls Church, VA
    gently tap components with the plastic end of a screwdriver
    Aug 2005
    Anaheim Hills, Ca
    Send it to yourself using UPS and make sure u tell them how much it's worth...
    PostCount++
    - SrCsTc's Bezel
    - Alpine W200/H701
    - ED Nine.2X
    - OZ Matrix Elites
    - ED Nine.1
    - Idmax 12's
    Mar 2006
    I think it might be overheating within seconds, could it be a temperature sensor is shot?(is there even such thing?)
    Aug 2005
    Anaheim Hills, Ca
    If there is a loose ground connection anywhere in the amp, this will cause the amp to quickly overheat. Open the amp up and follow the ground lead (starting from the connection terminal). Make sure that the ground on both ends of that is secure and there is no room for wiggle.
    PostCount++
    - SrCsTc's Bezel
    - Alpine W200/H701
    - ED Nine.2X
    - OZ Matrix Elites
    - ED Nine.1
    - Idmax 12's
  1. PC Motherboard to 1 amp or 2?
    By hanzacra in forum General Hardware Discussion
    Last Post: 11-27-2007, 03:41 AM
  2. Hard drive shock / vibration thoughts
    By S11D336B in forum General Hardware Discussion
    Last Post: 09-27-2006, 12:40 AM
  3. Amp running hot...??
    By Emerica2843 in forum General Hardware Discussion
    Last Post: 02-08-2006, 06:40 PM
  4. Amp running hot...??
    By Emerica2843 in forum Car Audio
    Last Post: 01-29-2006, 08:29 PM
  5. vw mk4 monson amp and another amp
    By colorless in forum Car Audio
    Last Post: 10-03-2005, 01:32 PM
