Results 1 to 6 of 6
Thread: two touchscreens pls help
    Apr 2006
    Question two touchscreens pls help
    i need some help. i just bought a truck and want to install two vga touchscreens in my sunvisors. i want to be able to use either moniter, for example if the passenger wants to select a song on my car computer i want to be able to use the passenger moniter, or vise versa. i want both moniters to view the same thing and be able to make a selection on either moniter. hope that makes sense any help would be appreciated. thank u in advance.
    Elsewhere
    All you need is a VGA splitter so they'll show the same thing.
    How about the Wiki?
    Apr 2006
    the moniters use usb for the touchscreen part. how would i go about doing this? would i just plug both them in seperate usb ports? im new at all this stuff.
    _
    Mar 2004
    Little Elm, Texas
    makes sense to me
    but what does this have to do with car audio?
    wouldn't this belong in the screens section?
    Jan Bennett
    Jul 1999
    Birmingham, Alabama (War Eagle!)
    yeah it should work the same way as having to monitors hooked up t your home computer as well as 2 mice hooked up, both mice would work independently of each other.
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    merde! this has been asked many times before!
  1. how to get OSK in PLS??
    By thanatos106 in forum FrodoPlayer
    Last Post: 06-12-2005, 07:02 PM
  2. question about touchscreens, and interesting device found
    By yalborap in forum General Hardware Discussion
    Last Post: 02-09-2005, 08:18 AM
  3. Theory on why Lilliput touchscreens die
    By archimense in forum LCD/Display
    Last Post: 08-27-2004, 01:12 AM
  4. Replies: 1
    Last Post: 02-27-2003, 07:29 AM
