Little confused.... but unless her factory unit specifically says it will play an mp3 or wma cd then you'll need to burn as a normal audio cd.
Hey guys,
I have a quick question and I don't have time to do a bunch of searching and reading. A friend is over and wants a copy of an audio book I have, which is recorded as an MP3. She has the factory stereo head unit in her truck.
What format should I record this audio book onto cd so that it will be compatible with her HU. Should I use MP3, WMV, etc?
8" Lilli TS
MB896F Mini-ITX MB
2GHZ Dothan 533MHz FSB CPU
1GB SDRAM DDR2 533
Seagate 300GB SATA150 HD
ENGENIUS WiFi MINI-PCI CARD 802.11A B 400MW OUT
Pioneer Slot Load SLIM DVDRW
Bluetooth V2 USB 2 Dongle
3COM BKP Cam
Nick
'99 Ford Escort ZX2 CarPC <-- RIP Feb '07
2006 Chevy Equinox LS (Current Project)
**VIA EPIA PD 1ghz Mobo, OPUS 150, 7" LinITX LCD touchscreen, 512 Ram, 60Gig HD, DLink Bluetooth, Belkin 802.11g wireless,
nkotch,
What format would a normal audio cd be? Is that a cda format?
8" Lilli TS
MB896F Mini-ITX MB
1GB SDRAM DDR2 533
3COM BKP Cam
Correct me if i'm wrong, but i think standard CD format is .WAV
But your CD will have to be burned as an audio CD, not a data .WAV
Yea, CD-DA or RedBook. What are you burning it with? Doesn't it have an Audio CD profile/format?
EDIT: Just looking at the above post..... yea, the audio file should be in the .wav format, those usually a burning program can use most audio formats to burn an Audio-CD, it just first converts the file to a .wav and then burns it. But you can't just burn the .wav file to a cd like omega said, that's just a data cd with a file on it.
Nick
Okay, so I convert it to a .WAV and burn it as an audio format. Perfect! Thanks guys.
8" Lilli TS
MB896F Mini-ITX MB
1GB SDRAM DDR2 533
3COM BKP Cam
Any burning software I have ever used has had the option to burn as audio cd (even from .mp3). So it should convert it to cda format for you.
My Work Thread:
http://www.mp3car.com/vbulletin/show-off-your-project/72552-mp3-project-for-land-cruiser-done.html
Source switcher for Lill
http://www.mp3car.com/vbulletin/show...d=1#post841007
