do a search - this has been covered numerous times...
IMO - not a single one is worth a damn.....but others disagree..
search....and ye shall find
I've gone through all the possible options...and i've finally come to the conclusion that i need a wired fm modulator.
I'd like get everyone's opinion on what the best ones to use are...
I know there are a lot of them out there, but I was just curious if anyone had some recommendations...
Thanks!
Car: 2002 Nissan Altima
Computer: Powerbook G4 12"
Current Status: 7 %
- audio inputs are done!
- front row is installed!
Current pics of my install
Jan Bennett
I have had good luck with the audiovox.
It would be best to find another answer though.
TruckinMP3
Read the FAQ!
The problem I have found with FM transmitters (both wired and wireless) is noise gets into the system when you power them off the car battery. Otherwise I get a clean signal when I power them off batteries.
I have no intention of having to change batteries every week or so. The car computer setup is supposed to make my life easier, not harder.![]()
Tried powering it from your PC's PSU?Originally Posted by piabu
Then you are doing something wrong.
TruckinMP3
Read the FAQ!
