If your ground wires are long enough, you could use a seatbelt bolt. There's nothing that says you can't drill your own hole and use your own bolt. If you do this, make sure to use a locking washer (they have little spikes on them) and sand down the paint to bare metal. ALWAYS check what is on the other side of the metal before you drill. The last thing you want to do is put a hole in your gas tank.
To crimp 4-ga wires I sometimes just use a hammer. Those 4-ga crimp terminators are usually pretty strong and even a standard crimping tool will be difficult to use.
You can put the crossovers in the doors if you want. It will save you running a second set of speaker wires through the door jam (which is my least favorite part of installing car audio equipment). Just find a place where there is extra space back there and use double-sided-tape to secure it. Do not put the crossovers on the inner door...there is significant moisture there when it rains and the window needs most of that space to roll down.
For stand offs, you can prolly find something at home depot. You could always just cut a wooden dowl and drill holes through it.
LinkBack URL
About LinkBacks
