Well, heck, I think I managed to find it after all, here
I'll go see if it works now
Dave
I know this has been posted before, but today is not my day, since I can't seem to find it.
My question is, how do I mix the center channel on a 5.1 setup to be played through the front left and right channels? My setup is an Audigy SB 2 NX (the external USB), with three lines from it, to my front amp, my rear amp, and my sub amp. The sub line also doubles as a center line in the Audigy, but I don't want the center channel played through there, I want it mixed into the front L/R.
The obvious answer is to set the speaker setup in the Creative Console to 4.1, except there is no 4.1 option. There is 4 channel option, but then there is no sub (.1) output, which is not what I want.
Any ideas? Or even a link to a thread that talks about this, since I can't seem to find it.
Dave
Dave
I didn't quiet get your problem but i had something simillar.
My sub amp is 2 ch. the sub/center output on my 5.1 x-fi gives out mono output so i had to use a converter (splitter):
3.5 mono jack ==> 2 RCA outputs.
now i have the mono signal split to 2 rca outputs for my subs amp
Final Touches
Car: 2002 Mitsubishi Magna EI
CarPC: SP13000, M2-ATX, 512 MB RAM, 120 GB 2.5" HD, X-Fi Sound Card, Xenarc 700TSV, Garmin 18 USB.
Audio: 2X15" Rockford Punch Z, 1 Rockford Punch 2-ch Amp, 1 Soundstream Lil Wonder II 4-ch Amp
Bah, that solution doesn't work for me.
The above was the listed solution, but on my Windows Mixer, the "Other" is grayed out. Anyone have any ideas?In Windows mixer (Dbl click the speaker icon in the tray) go to the Options menu then Properties. There should be 3 radio buttons - Playback, Recording and Other. Select "Other" and you should have the option in a pull-down box of "Multi Channel" or something similar. Press OK and the front, rear, center and LFE channels appear as sliders. Under the Rear Speaker slider there is an Advanced... button. Clicking this brings up some more options. Here you can alter the Bass/Treble of your sound (if supported - my soundcard doesn't), and below are the options "Magic5.1 Enable" (which mixes any stereo sound to use all channels - so your music will come out of all speakers - very handy!), and "Mix Surround to Front".
The Advanced... button under the Center channel slider also has two options: "Exchange Center/LFE" (swaps bass and center channel around), and "Mix Center/LFE to front" (This is it! and it works flawlessly. Check this box and the sub and center channel will mix to the front speakers. Dont worry about the sub channel as your speakers probably wont sound those frequencies anyway.)
Dave
i've been researching this as well. Funny thing...creaive si the onlyone who thinks that their system has a 4.1 setting.
Anyways, here's the tutorial on how to connect the card to a 4.1 system (one of Creative's no less...)
http://dmzweb3.europe.creative.com/S...3895):obj(3907)
Carputer Progress: Here we go again...
THE GF THEME
Genesis has speed
Genesis has class
Genesis sent money
before your a__;)
Join the fight against carputters. EMAIL ME!
From that website:
Kind of funny, since THERE IS NO 4.1 SPEAKER SETTING!!!In the Creative Surround Mixer, choose 4.1 Speaker in the Speaker Settings window, and deactivate the option Digital Output Only.
That is really annoying. Not on your part, Genesis, but on Creatives.
Oh well, back to the drawing board.
Dave
what's worse is that i just did the automatic updates, hoping a 4.1 setting would pop up and i'd get my first sticky ever...no dice...:P No sticky![]()
THE GF THEME
Genesis has speed
Genesis has class
Genesis sent money
before your a__;)
