Results 1 to 7 of 7
Thread: Powering carpc and amp
    Apr 2006
    Hi everyone, I have recently installed a carpc that is working great. I am using a MII12000 mbd with a M2-ATX 160W power supply and about 3 usb and 1 firewall device. I've calculated I am running about 90W. I would like to add a sub box to my car. I've been looking at a sub and amp combo like the bazooka or infinity. I would really like to keep from running another power cable to my trunk from the battery. Would it be a problem using a distro block to split the power between my carpc and my sub box? I am running 4 gauge cable. Also, I Should I also add fuses at the distro box going to each device? Thanks.
    Elsewhere
    That's the whole purpose of a distribution block, so yeah, it will work.
    Fuse each line, of course.
    How about the Wiki?
    Apr 2006
    Thanks for the reply. My biggest concern was that I wasn't overloading the 4guage power cable. The last thing I need is to start my car on fire.
    Any suggestions on size of fuzes?
    Elsewhere
    Whatever is recommended by the amp manufacturer
    How about the Wiki?
    Variable Bitrate madkad's Avatar
    Jul 2005
    uk
    LOL I have 3 amps in my car attached to my car pc, along with two subs, to 6 b 9's and others
    Its great for poping out some good tunes
    just to let you know though I had some really big problems getting the whining sound to go to the background in the amps
    [B]Car Computer 98%[|||||||||-]
    Install Plan 100%[||||||||||]
    Styling 20%[||--------]
    Install 0%[----------]
    Newbie freak3dot's Avatar
    Mar 2006
    Indianapolis
    I just d "wire gauge table" and found the following website:
    http://www.rbeelectronics.com/wtable.htm
    I can't guarantee I'm reading it right but it looks like you are good up to 1200 watts (In reality it is more like whatever your battery is capable of). I'm assuming your 4 gauge wire is less the 15 feet in length and of course that the voltage is 12V.
    freak3dot - Computer Science Degree
    1994 Chevy Cavalier
    Phase 1 parts purchased.
    Variable Bitrate viper24's Avatar
    Oct 2005
    Sacramento, CA
    for a 4 gauge under 15 ft, I would stay under 1000 watts total. Nothing will burn up, you just might not get the amount of sound and power you can. I would throw in a hefty 2 gauge and not worry about anything. Its only about an hours worth of work.
    2005 Dodge Ram HEMI
    http://www.cardomain.com/ride/2239451
    15" LCD touchscreen
    Mac Mini
    6" Headrest monitors
    Modded Xbox
    5 PSone screens going in doors
    And another 15" LCD!
  1. Power AMP from CarPC
    By kiwiruss in forum Car Audio
    Last Post: 03-16-2006, 01:52 PM
  2. Replies: 9
    Last Post: 07-31-2005, 08:32 PM
  3. Replies: 4
    Last Post: 05-17-2005, 05:17 AM
  4. Powering AMP and CarPC
    By loscooby in forum Car Audio
    Last Post: 03-31-2005, 12:48 PM
  5. Those with a hu, amp, and carpc
    By falconey in forum Car Audio
    Last Post: 09-14-2004, 08:27 AM
