Yeah, I'd check for power on the wires you used. A volt meter would be best, but if you don't want to bother you can try connecting the wires to another device - something simple like a cell phone car charger.
Ok....
I installed a wired fm modulator into my car today....
I ran the box directly into the back of my car's antenna and because the unit required a 12v power source and ground source, i decided to dismantle my un-used cigarette lighter adapter and use the ground and 12v power source attached to that for my FM modulator. (this ended up working out extremely well, because there was a cigarette lighter adapter sized on/off switch that came with the modulator that fixs perfectly)
(The only evidence of my install...i have to admit, it looks pretty good, haha) -
http://www.flickr.com/photos/28787159@N00/125908717/
So anyway, i hooked everything up....tried it out...and it worked great!
I dismantled all the pieces and started reassembling them so that wires werent exposed at all. After all is said and done, the install looks great....so i go to try it out again....nothing....
Its the same exact setup as i had 5 mins previous, but it doesnt work....
I checked my cars "audio" fuse in the fuse box....it looks fine
I checked my fm modulators fuse and internal components...they look fine
I checked my car stereo's internal components...they all look fine
I even disambled the button and it looked fine.
My only thought left was that maybe I blew the fuse for the cigarette lighter....but...my other cigarette lighter adapter works fine. Unless they are on seperate ciruits, I dont know what the problem could be....
I'm looking for some suggestions of what to try next....
The only thing i can think of doing is going and buying a volt meter and testing the wires that are supposidely "powering" my fm modular...
Thanks guys.
Car: 2002 Nissan Altima
Computer: Powerbook G4 12"
Current Status: 7 %
- audio inputs are done!
- front row is installed!
Current pics of my install
How would i go about doing that? Do you know which parts of a CLA are the hot and the ground, as in where we i would connect the wires?
Current Status: 7 %
You could also test with an test-light. Or just an automotive light bulb. By using a light bulb you could connect it either way, not worrying about polarity for now. If the light bulb shines, you've got power. Measuring the voltage with a meter would be a better option though.
So...........good news and bad news....
The good news, i got a voltmeter!
The bad news, the wires that had previously been supplying my cigarette lighter adapter with power are outputing 0V and when i went to go test my other cigarette lighter adapter with my voltmeter it turns out that my other cigarette lighter adapter is also broken now!
Ya, so i'm lost.....i guess i have to find the inline fuse for both of these adapters because there's no fuse for them in the fuse box on my car.
Current Status: 7 %
Sure you don't have two fuse blocks?Originally Posted by wheli
My car does. One under the hood, one inside the interior.
ya...i checked both...none for the cigarette lighter adapters....
I checked all that were even slightly related and they all looked fine....
I'm pretty sure its inline.....
-----actually, im starting to think that maybe wiring my modulator directly to my cigarette lighter wasnt the best idea....was i wrong in thinking that this would work?
Current Status: 7 %
Check to see if yoour meter has a continuity tester that beeps when the probes touch each other. If it does, use that setting to test each one fo the fuses by touching the probes to the small metal tabs on the top of each fuse. If the fuse is good, your meter will beep. If it does not beep, then the fuse is blown.
it doesnt have one of those unfortunately.....
i think im just gonna buy a 10 pack of 10 amp fuses from radioshack or something and replace all of my 10 amp fuses for 5 bucks, haha.
maybe that will fix it....
Current Status: 7 %
y dont you just check all 10 to see if they are working. wouldnt that just be easier.
