I'm assuming the power is DC. If so, not a problem. Problems arise from AC current inductance; one wire's alternating current induces a similar, but smaller signal in parralell wires.
Input/output in the same bundle? if they're shielded, it shouldn't be a problem. otherwise, you may get some cross-talk. Is it coax or colinear? high-end coax is usually shielded.
LinkBack URL
About LinkBacks
