Why don't ya try the manual for your motherboard?![]()
http://www.via.com.tw/download/mainb...a-mii_v150.pdf
Looks like there's a feature you turn on in the driver and then the lineout becomes the rear output, and the mic becomes the sub output, but you lose the mic and line in connections. Or, you can use the SPDIF digital connection but would have to find a digital-analog converter to go to the amp.
Are you trying to run multichannel audio in the car or just the same stereo feed to front and back. If you're not trying to do surround then just put a splitter on the line out to feed both the inputs, or some amps even have a switch where you only need one set of inputs to feed all channels.
LinkBack URL
About LinkBacks
