Results 1 to 4 of 4
Thread: Proper Wiring to prevent noise!!!
    Apr 2006
    San Antonio, Texas
    Lightbulb Proper Wiring to prevent noise!!!
    Okay, I've seen a few people ask questions regarding this extremely frustrating problem. Alternator noise, or ground loop interference. This is easily fixed.
    I found this site, seems to give the solution simply:
    Proper Wiring
    Amp Power Wiring
    Hope this helps
    Oct 2005
    Lol... it's NOT easily fixed ... you can try to avoid it, but sometimes it just happens, it can be components, anything.
    In my setup, I get the interference from everything, I have no idea why, my computer emits noise on it's audio cables, the head unit emits noise, etc... I had to use a total of 6 ground loop isolators to fix the issue, cut the noise right out. Nothing to do with wiring, **** happens and you gotta fix it.
    Feb 2006
    I could fix everyones problem with noise if I was good at explaining things. I'm the type of person who has to be the one fixing it to fix it.
    Out of the entire time I installed car audio I never had a problem with noise.
    50% of the noise is from the installation and the other 50% is from ****ty cables.
    FLAC TheLlama's Avatar
    Jul 2004
    All over the world
    Mine was actually poor factory wiring. I replaced the speaker cables and wired my own power to my amps before I even heard what the system sounded like. I had noise afterwords and it was the ground to my head unit. Took forever to track down, stupid factory.
  1. Engine Noise due to ground loop or amp?
    By matt11601 in forum Car Audio
    Last Post: 08-26-2009, 09:38 PM
  2. Alternator Whine Only With Carputer
    By tbird2340 in forum Car Audio
    Last Post: 06-29-2007, 03:36 AM
  3. Got rid of BUZZ noise!!
    By bleunetizen in forum General Hardware Discussion
    Last Post: 10-30-2005, 08:20 PM
  4. Troubleshooting: NOISE
    By RedGTiVR6 in forum Car Audio FAQ
    Last Post: 03-26-2005, 11:31 AM
  5. noise investigation
    By lookinco in forum Power Supplies
    Last Post: 09-23-2004, 03:41 AM
