Results 1 to 8 of 8
Thread: IS my capacitor bad?
    Apr 2005
    Queens, New York
    OK so I I am trying to install my new system... I connect all the powers, grounds and remotes to where they needed to be. OF course doing all this while the power wire to the system is disconnected from the battery. So after everything is connected i go to turn on the car and all of a sudden i am getting a buzz from the capacitor, i shut the car off. ANd stupid me I forgot to put the power wire coming from the trunk back on the battery. SO i connected the pwer wire back and i get no buzz but my cap doesnt turn on. I use my multimeter and I get correct voltage everywhere but the cap isnt turning on and it will obviously not turn my amps on. Does the cap just need to be recharged or is it a bad cap now?
    2002 Mitsubishi Galant
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    Souund Blaster Audigy2 NX
    OPUS ITX PC Case
    Low Bitrate ilyassx's Avatar
    Oct 2005
    Belgium, Denmark
    May be the cap need to be recharged, you must first charge your cap using a 1K ohm resistor and a multimeter to watch the charging process until read 12 V. also be careful do not hold the resistor with you hand you could be burned, the current flowing through the resistor will cause the resistor to heat up.
    Hope this help.
    The old setup http://flickr.com/photos/ilyassx
    The new setup http://my.opera.com/ilyassx/albums/show.dml?id=110701
    Jetway J7F2WE VIA C7 1.5 GHz
    512 DDRII 533
    3.5" SATA2 H.D.D 200GB
    M1-ATX
    ELM327MS OBDII
    Creative Audigy 4
    PROGRESS:[########-]90%
    Apr 2005
    Queens, New York
    My cap, the voltage IS reading 12.4 on the remote and power....Would the cap just lose charge?
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    OPUS ITX PC Case
    Apr 2005
    Queens, New York
    I called up tech support, they said i need to recharge it with a 27ohm resistor...I checked radio shacks website and they dont carry it, where can i get a 27ohm resistor?
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    OPUS ITX PC Case
    Oct 2005
    Belgium, Denmark
    May be the problem comes from the remote, try to connect the cap directly to the battery positive use the same positive wire to both remote and main power cap positive, and look what will happen.
    512 DDRII 533
    M1-ATX
    ELM327MS OBDII
    Creative Audigy 4
    Oct 2005
    Belgium, Denmark
    Quote Originally Posted by Cheekz185
    the exact value of the resistor is not critical but i recommend you to keep in the 500-1k ohm, your cap should come with a resistor for charging.
    Use this one http://www.action-electronics.com/resist1w.htm
    512 DDRII 533
    M1-ATX
    ELM327MS OBDII
    Creative Audigy 4
    Apr 2005
    Queens, New York
    Quote Originally Posted by ilyassx
    Thanks, that worked i appreciate it!
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    OPUS ITX PC Case
    Oct 2005
    Belgium, Denmark
    You're welcome.
    512 DDRII 533
    M1-ATX
    ELM327MS OBDII
    Creative Audigy 4
