Results 1 to 10 of 16
Thread: First carputer...
    Newbie ComputerDoctors's Avatar
    Apr 2006
    Question First carputer...
    Hello everyone...got a quick question. I'm designing my first carputer and I'm looking at the various parts. I want to put in one of the Intel-based mb (the MB896F) but I dont see anywhere if it supports 5.1 audio on-board. I know the VIA boards have that capability, but I dont see it for the intel.
    Is anybody using that (or another) intel board and know that is supports 5.1?
    Any links to documentation on that board would be very helpful.
    Thanks,
    Amit
    Maximum Bitrate 3onDubs's Avatar
    Aug 2005
    Anaheim Hills, Ca
    You don't want to use onboard audio.
    PostCount++
    - SrCsTc's Bezel
    - Alpine W200/H701
    - ED Nine.2X
    - OZ Matrix Elites
    - ED Nine.1
    - Idmax 12's
    Apr 2006
    Then what would you recommend? I'm not all that interested in surround sound in my car...but I do want to keep fader control. There will be no HU in the setup. Also, I want decent sound quality....but not looking to win competitions.
    oh yea...trying to keep the pc small....the board only has 1 pci slot.
    -Amit
    Newbie 0verfiend's Avatar
    Jan 2005
    Chicago, IL
    I see a lot of people here running a usb hub, and connecting most of the things inside home PCs via a usb... so a usb sound card.
    Aug 2005
    Anaheim Hills, Ca
    I don't have that much experience with car audio, but i can tell you what i've done and learned based on my install.
    First, i went with an external sound card and 3.5mm to rca cables going to my amps. My sound sucked @ss....i couldn't hear my subs, got tons of speaker whine...overall wasn't loud or clear.
    I then replaced my speakers and amps. Slightly better because of the quality improvment, but the source (soundcard) was hurting. It wasn't all that bad, but i just kept comparing it to when i had my head unit in....and it was nowhere close. I just couldn't be satisfied with the speaker pops and alternator whine and i tried everything to get rid of them...pop stoppers, noise isolators, changed grounding points, shared grounding points...nothing worked.
    I then got a digital sound processor...the H701...and all of my problems went away....THE END
    lol....the alpine won't win you audio competitions necessarily, but it will put you on the same level as a head unit, so that you have the same potential and sound quality.
    PostCount++
    - SrCsTc's Bezel
    - Alpine W200/H701
    - ED Nine.2X
    - OZ Matrix Elites
    - ED Nine.1
    - Idmax 12's
    Apr 2006
    Yea, I considered that option, but what I'm trying to do is keep everything in the double din casing . So the USB option doesn't really work.
    What I really need to know is: does the M896F supports the multichannel (5.1) sound?
    Also, do I need 5.1 for a car or is there something like 2.1 (I absolutely need a subwoofer out)?
    Aug 2005
    Anaheim Hills, Ca
    4.1
    PostCount++
    - SrCsTc's Bezel
    - Alpine W200/H701
    - ED Nine.2X
    - OZ Matrix Elites
    - ED Nine.1
    - Idmax 12's
    Apr 2006
    Quote Originally Posted by 3onDubs
    Pls send me a link to the H701...lemme look into that.
    Aug 2005
    Anaheim Hills, Ca
    PostCount++
    - SrCsTc's Bezel
    - Alpine W200/H701
    - ED Nine.2X
    - OZ Matrix Elites
    - ED Nine.1
    - Idmax 12's
    Aug 2005
    Anaheim Hills, Ca
    But this alpine would have to sit somewhere else as it won't fit in the double din casing. It also requires the controller (which is only like an inch tall) to be mounted so that u can higher and lower the volume. I find this a plus (having a volume nob), while others see it as a minus (no place to put it).
    If you went with the alpine, your going to need a mb that has spidf out. I'm pretty sure that all of the via epia's have this...make sure urs does too.
    PostCount++
    - SrCsTc's Bezel
    - Alpine W200/H701
    - ED Nine.2X
    - OZ Matrix Elites
    - ED Nine.1
    - Idmax 12's
  1. 99 Acura TL carputer project pics
    By Darkshear in forum Show off your project
    Last Post: 08-23-2007, 01:14 AM
  2. Replies: 6
    Last Post: 03-20-2007, 11:16 PM
  3. My 2006 Scion xB (portable) Carputer setup! w/pics!
    By breaker021 in forum Show off your project
    Last Post: 01-05-2007, 10:34 AM
  4. Replies: 9
    Last Post: 08-07-2005, 12:27 PM
  5. carputer install: I dare you...
    By Cat Monkey in forum General MP3Car Discussion
    Last Post: 01-27-2005, 06:34 PM
