Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: PRA-H400 w/out HU power up
    Apr 2006
    Sorry about the double post in general.
    Is there a way to get the apline H400 DSP to power up without a head unit. I know my unit works since I was able to hook the AI-net up to a friends car and the unit power up.
    If not which DSP will power up with out a head unit that have optical input.
    H600, H510, H7001, H701
    I've done the search option.
    Maximum Bitrate 3onDubs's Avatar
    Aug 2005
    Anaheim Hills, Ca
    Can you post a picture of the power harness that plugs into the back of the H400?
    If you can do that, i can tell you which wire (if any) is the remote wire. In the Alpine manual, it will tell you that if you don't have an ai-net head unit, you are going to need to use a remote turn on wire to turn the unit on. On my H701, the harness had all of the wires labeled (luckily), so i just used the amp turn on lead from my power supply to turn on the DSP.
    Hope this helps...oh yeah, it was the blue wire comming out of the harness (yellow is power, black is ground).
    EDIT: The reason why you don't need a turn on wire with an ai-net head unit is because the ai-net connection has this function incorporated.
    PostCount++
    - SrCsTc's Bezel
    - Alpine W200/H701
    - ED Nine.2X
    - OZ Matrix Elites
    - ED Nine.1
    - Idmax 12's
    Apr 2006
    The wiring harness has 3 wires coming out of the unit. They are labeled
    Yellow - battery
    black - ground (no label)
    blue - remote out
    I've tried applying a 12 volt signal on the blue and yellow wires and a ground on the black but the unit will not power on. I'm thinking I'm screwed with this DSP.
    Aug 2005
    Anaheim Hills, Ca
    Quote Originally Posted by shefron
    Yellow - battery
    blue - remote out
    Hmm...that's strange. It should power on if everything is connected properly. I would try and contact Alpine technical support directly (email or phone call) and ask them if it's possible to use the unit without the ai-net connection. I don't know if anybody else on here is using the 400 model (cuz they havn't chimed in), but maybe this model needs a controller. Do you have a controller to use with it? If not, how do you control it?
    PostCount++
    - SrCsTc's Bezel
    - Alpine W200/H701
    - ED Nine.2X
    - OZ Matrix Elites
    - ED Nine.1
    - Idmax 12's
    Apr 2006
    nah i can't find a controller for the unit. I don't think I could find anyone with a unit on here.
    Aug 2005
    Anaheim Hills, Ca
    I couldn't find anything on that either...the best bet would be to send them an email and hope you get a quick response.
    PostCount++
    - SrCsTc's Bezel
    - Alpine W200/H701
    - ED Nine.2X
    - OZ Matrix Elites
    - ED Nine.1
    - Idmax 12's
    Apr 2006
    sorry about taking so long for a update.
    I tried to fool around with the unit for a bit then just said screw it. I bought a PXA-H510 system for 150 off ebay. When I have free time this summer I'll see about modifiy the unit to work without Ai-net.
    Aug 2005
    Anaheim Hills, Ca
    $150? That's a great deal...about the same price as a high end soundcard.
    PostCount++
    - SrCsTc's Bezel
    - Alpine W200/H701
    - ED Nine.2X
    - OZ Matrix Elites
    - ED Nine.1
    - Idmax 12's
    Oct 2004
    NY
    the 510's go around 150-200 depending & are one of the best bang for the buck.... the 400 should power up with +12v on yellow & blue, black -.... if it's not powering up then theres a problem....
    the 510 is a much more versitale unit than the 400, which is mainly a high end crossover anyway... most high end installs will use 2 400's.... there are no modifications required to use either of these non ai-net from what I remember....
    Apr 2006
    Quote Originally Posted by turbocad6
    The blue on the 400 is only for a remote out to a amp. I tried connecting the yellow + the blue to a 12+ and the black to ground with no luck. But the unit did power up perfectly when I hooked the yellow to 12+ , the black to ground and hooked the Ai-net cable from my friends Alpine deck to the unit. So I know the unit works.
  1. FAQ: Installing a Mac Mini in Your Car
    By Bugbyte in forum The FAQ Emporium
    Last Post: 06-11-2011, 09:12 PM
  2. HOW TO:use opus with a laptop......
    By turbocad6 in forum Power Supplies
    Last Post: 06-25-2009, 07:31 AM
  3. Power supply Problem
    By xGROMx in forum Power Supplies
    Last Post: 03-16-2007, 02:19 PM
  4. Power inverter problem.
    By blackedoutxb in forum Power Supplies
    Last Post: 11-14-2005, 10:51 AM
  5. Low power alarm, kind of
    By System-f in forum Power Supplies
    Last Post: 03-11-2005, 01:48 PM
