Results 1 to 10 of 16
Thread: Successful VGA to head unit yet?
    Dec 2003
    Sunny SoCal
    Sorry, been away trying to get ready for next db drags, still on the carputer seen with my xenarc and laptop (represent) but unfortunately I an told somewhere between 150 and 160db my laptop will quit, and I may have to add a head unit for comps .
    Not really using my touchscreen like I thought I would either, so I'm wondering...
    Has anyone been successful yet at using a (quality) head unit with screen as their vga input?
    I know someone was trying to crack Clarion, and I thought a certain Pioneer might?
    Thanks, I apoligize for not reading and following you guys as much as I used to, but I am out there in comp scene passing the word about us (MP3CAR.com) .
    Elsewhere
    Read the forums, then.
    Someone hacked a Kenwood unit, I believe.
    And who told you that your computer would fail at a certain decible level? Why would it?
    How about the Wiki?
    Dec 2003
    Sunny SoCal
    Quote Originally Posted by DarquePervert
    No one had to tell me, I've seen it happen. 150 - 160db and it will shutdown or freeze. Mine is doing weird things and optical mouse will not function at full volume and as of right now I am making the jump to about 7500 watts to 2 subs if you are wondering what it takes to freeze yours.
    Enough db and your body will fail too.
    Probably because the hard drive can't take it.
    1995 Saturn SL2
    Carputer removed.
    Pioneer DEH-P880PRS head unit
    Soundstream Rubicon 600-4 4 Chan Amp
    Diamond Audio D661s components w/Active Crossovers
    MB Quart RAA1000 monoblock amp
    2 Alpine Type R 1041D 10"s
    My man uses Levitra. Peoples's Avatar
    Dec 2004
    Maryland
    that doesnt make sense......your laptop isnt producing the decibles.........i could see if maybe you had it right against a huge *** sub's magnet......but even then....
    PC Components:
    My work log
    Dec 2003
    Sunny SoCal
    Quote Originally Posted by Peoples
    Comp is maybe louder than you think, if you sat in my truck, you might understand what happens inside a computer, and everything inside the vehicle.
    Dec 2004
    Maryland
    .....unless you bought a laptop with a built in amp.....your computer is not generating that much sound.....the amp is doing it. Thus cranking the volume on the computer.....will not make it freeze/crash
    PC Components:
    My work log
    FLAC sama's Avatar
    Feb 2006
    London, UK
    either you can use a top brand head unit with a hacked display
    or
    you can go about solving why your laptop is crashing.
    if you want to do the second one, I would suggest checking another laptop in the car. failing that, there are a zillion things that can be done to stop if from shaking, or being affected by shaking. For example, you could boot off a compact flash card in a read-only operating system mode. that would mean your system cannot crash from vibrations unless a you get hit by a stray astroid!
    lots of things to try
    Dec 2003
    Sunny SoCal
    Quote Originally Posted by sama
    or
    Must play comp cd given to you.
    Never said my laptop has crashed, but it will as I get louder, right now it has failed to respond (pause) a few times (remote) and I have had to get in and turn it down (painful). In reference, people in my class are blowing their windows out and external podiums for signal units are common, but I don't want one yet.
    From what I understand:
    High end changer < head unit < laptop in terms of db tolerance.
    And yes, finally to get back on topic, a hacked high end head unit is EXACTLY what I need (hence thread title).
    Any ideas?
    FLAC sama's Avatar
    Feb 2006
    London, UK
    not from me! I'm not a comp man, more a computer man
  1. Sound Card and Head Unit
    By cadence117 in forum Car Audio
    Last Post: 02-12-2008, 07:34 AM
  2. Can a car-computer replace a stereo head unit?
    By CA 3000GT in forum General Hardware Discussion
    Last Post: 11-13-2006, 10:24 PM
  3. Head Unit: Sony/Panasonic?
    By OdoyleRules in forum Car Audio
    Last Post: 02-25-2006, 07:03 AM
  4. Stock Head Unit
    By Rmk1139 in forum Car Audio
    Last Post: 06-16-2005, 04:25 PM
  5. In house head unit
    By EPIK in forum General MP3Car Discussion
    Last Post: 02-27-2004, 07:50 AM
