Results 1 to 5 of 5
Thread: Clarion VRX935VD Help??
    Apr 2006
    Im not sure if this is the right section. I wanted to ask you guys what could be wrong. My deck is starting to give me some problems. The buttons on the screen have stopped working except for the menu button. Also my dvds have started to skip an also stop in mid view. Is there anythin that I can do to fix this or do I need to send this to a pro an have them fix it.
    My man uses Levitra. Peoples's Avatar
    Dec 2004
    Maryland
    replace it with a car computer?
    PC Components:
    My work log
    Elsewhere
    No, this isn't the right place to ask.
    Regardless, I'd take it to a pro, especially if it's still under warranty. If not, you may want to consider simply replacing the headunit, as it's very likely that the cost of repair will approach the cost of a new headunit.
    How about the Wiki?
    Apr 2006
    Sorry I didnt know. Aight thanks for the help.
    Oct 2005
    Hou. TX
    One good thing about a carpc is that almost all the parts cost under $100 each(minus the LCD). So it's not too bad if one part goes out. That Clarion is a pricey sucker. It's either all or nothing. I'd have Clarion take look at it and get an estimate.
    If it were just the buttons you might could open it up and see if they are sticking or something, but if the DVD is freezing then I'd say you have an electrical problem that a pro would have to fix.
    1999 Black Pontiac Trans Am
    CarPC's in F-bodies
    How To Relocate Climate Controls on the 97-02 F-body Cars
    (AMD Sempron 3000+, Opus 150)
    Car PC system is out, Alpine system is in.
  1. Replies: 5
    Last Post: 04-20-2004, 10:51 PM
  2. clarion VRX935VD
    By geoff897 in forum Newbie
    Last Post: 02-20-2004, 10:17 PM
  3. Clarion Marine, Aux In? Other Marine options?
    By JeeP-3 in forum General Hardware Discussion
    Last Post: 10-30-2003, 02:37 PM
  4. Clarion VRX935VD how would you set it up?
    By jeseyboy3 in forum LCD/Display
    Last Post: 08-26-2003, 10:16 PM
  5. FS: Clarion VRX610 LCD + Audio + Rims
    By gguy in forum Classified Archive
    Last Post: 11-22-2001, 11:09 PM
