Results 1 to 10 of 13
Thread: CD Changer plug to pc???
    Variable Bitrate madkad's Avatar
    Jul 2005
    uk
    Am I right in saying I can conect my car pc to my head unit with the CD changer cable?
    [B]Car Computer 98%[|||||||||-]
    Install Plan 100%[||||||||||]
    Styling 20%[||--------]
    Install 0%[----------]
    FLAC evandude's Avatar
    Mar 2005
    Maine
    it depends on the car. for instance, in volkswagens/audis and many others, the head unit will not accept input through the CD changer cable without a device attached which sends digital data packets to the head unit making it think that there is a real CD changer connected.
    But don't take it from me! here's a quote from a real, live newbie:
    Quote Originally Posted by Viscouse
    I am learning buttloads just by searching on this forum. I've learned 2 big things so far: 1-it's been done before, and 2-if it hasn't, there is a way to do it.
    eegeek.net
    Jul 2005
    uk
    I have the sony flip down head unit with a sony 10 disk changer, I was trying to thing of a way to wier that up this way.
    I removed my ford radio a long time back
    Any ideas if the sony will work?
    Jun 2004
    Rochester
    If you already have the CD changer hooked up and working, yes. You will have to hack up the CD changer cable and find the wires that carry the audio signal (Right, Left, and Ground). Then you can put in a switch and be able to switch back and forth from the changer to the computer. You can either get an Audio switch box or a 3PDT switch. With this solution you will most likely have to be playing a CD in the changer to enable the input.
    Peace.
    Constant Bitrate Legarcondemerde's Avatar
    Jul 2005
    The Biggest Little City
    Sonys use RCAs for the changer audio, so in theory all you would have to do is find a way to make the deck think the changer is plugged in so it would recognize it as another source. You can get a dual aux. input adapter for Sony decks that would allow you to keep your changer and add an aux, that would be the easiest and most reliable way to go, although certainly not the cheapest.
    Maximum Bitrate seanz0rz's Avatar
    Jun 2005
    Cal Poly Pomona or Redlands, CA
    i would also like to input into the cd changer input on my sony HU. unfortunatly, ive never ever found a way to get it to work.
    1998 Toyota 4Runner SR5 V6 4x4 in Evergreen Pearl Metallic, Lifted, Locked, and Armored. CarPc in custom console with molded touchscreen.
    Pictures
    Photobucket is being updated, if a picture i posted no longer works, please PM me.
    Jul 2005
    It's not cheap, but this will do it.
    http://www.crutchfield.com/S-54hRKoZ...asp?i=158XA300
    Jun 2004
    Rochester
    Yes, since the connection is RCA's already, as long as you wanted to keep your sony cd changer you wouldn't need to do any hacking at all. Just buy an Audio Switch box to switch the RCA's and poof-aahh, AUX-IN. On the other hadn the Dual Aux-In adapter would be expensive, but would make the switching automatic.
    Jul 2005
    Haha, yup, that would do it, I can't beleive I didn't think of that.
    Jun 2005
    so basically you need some way of spoofing that bus controll.
    for 100 bucks, i rather spend a little more, buy amps and speakers, and ditch the HU.
    any ideas?
    Pictures
  1. Delco units with CD changer input
    By Chairboy in forum Car Audio
    Last Post: 09-07-2008, 12:28 AM
  2. Clarion Drx9675 and Cd changer
    By Tommy152 in forum Classified Archive
    Last Post: 03-26-2005, 12:56 PM
  3. FS: Kenwood 10 Disc CD Changer KDC-C601
    By BiohazrD in forum Classified Archive
    Last Post: 11-09-2004, 07:47 PM
  4. FS/FT: Kenwood 10 Disc CD Changer
    Last Post: 10-22-2004, 12:40 PM
  5. Virtual CD changer software interface?
    By potatohead in forum Software & Software Development
    Last Post: 07-24-2003, 01:04 PM
