Results 1 to 6 of 6
Thread: Funky Sound Problem
    Feb 2006
    Funky Sound Problem
    i am running a laptop carputer set up. when the power invertor is on there is alternator whine and a weird crackling noise. i assume its a ground loop problem, but i hooked up an isolator the the audio out and it didnt fix it . any ideas/suggestions...i am using a usb external sound card that i got from best buy http://www.bestbuy.com/site/olspage....=1122654484359 . when the laptop is on battery it sounds great.
    Constant Bitrate godraj's Avatar
    Jan 2006
    east coast NY
    a power inverter will do that. i have the same problem, but i'm not sure how to fix it.
    Falls Church, VA
    its a dirty power supply and the power supply of the laptop cant clean it. You need a true sine wave invertor. Usually a bit more pricey.
    Why not use a 12v cig adapter for your laptop instead? Or a carnetix 1900?
    Feb 2006
    any suggestions on where to get a 12v cig adapter for my laptop?
    Maximum Bitrate 3onDubs's Avatar
    Aug 2005
    Anaheim Hills, Ca
    ebay
    EDIT: I saw an add in the paper yesterday that said..."You can get IT at ebay...whatever IT may be"
    PostCount++
    - SrCsTc's Bezel
    - Alpine W200/H701
    - ED Nine.2X
    - OZ Matrix Elites
    - ED Nine.1
    - Idmax 12's
    _
    Mar 2004
    Little Elm, Texas
    Quote Originally Posted by 3onDubs
    ebay
    as I have said for thousands of posts (hehe)
    an inverter is one of the worst ways to incorporate a computer in the car. They are inherently messy and induce so much noise it's unbeleavable. For the same amount of money that a GOOD inverter would cost you, you can get a GOOD dc-dc power supply. Not only will it be smaller, but it incorporates much more into it and is 100x easier to implement and use in a car.
    Not just talking about start-up and shut-down procedures here.
    Jan Bennett
  1. Laptop and low sound volume problem
    By Hark in forum Car Audio
    Last Post: 07-13-2005, 05:49 PM
  2. Audio problems, Epia Sound, and FAQ stuff
    By gothate in forum Newbie
    Last Post: 06-16-2005, 05:04 PM
  3. weird sound problem
    By jermaine in forum General Hardware Discussion
    Last Post: 06-04-2005, 03:11 AM
  4. the ever popular sound card problem....
    By RedGTiVR6 in forum General Hardware Discussion
    Last Post: 12-15-2004, 03:01 PM
  5. Replies: 7
    Last Post: 11-16-2004, 05:36 PM
