Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: I need help installing a CD/MP3 deck on my 97 Neon
  1. #11
    Dec 2005
    Yep my dash wasn't working but I replaced that fuse and now they're fine. slot 13 is empty there is no fuse to put there. I checked all fuses and found that the cigarette lighter fuse is burnt, I replaced it started the car and it burned again. i'm pretty sure I have the wires figured out, maybe a relay or something blew? or is there another fuse that effects the pink wire because I get no voltage on the pink wire just the red w/white stripe wire gives me around that much voltage.
  2. #12
    Jun 2004
    Rochester
    Quote Originally Posted by Mic4
    It sounds like you have a short somewhere. Are you sure none of those radio wires are touching anything they shouldn't be? Make sure there is no exposed wires that could touch each other or anything in the dashboard.
    The fuse for the pink wire is fuse#13 but it is located in the Power Distribution Center under the hood. Check this, I bet it will be blown too.
  3. #13
    Dec 2005
    Sweet!, it worked the radio is now thanks man your the **** and very happy today!
    One more thing, I noticed the speakers sound like crap, they're giving off a crackling noise specialy when I turn the volume higher, could that be a wiring connection problem?
  4. #14
    Jun 2004
    Rochester
    Double check all of your connections, particularly the connections to the speakers. Is it happening on all of the speakers? Does it happen whether the car is running or not? It sounds like your speakers are blown. You said it happens when you turn the volume up. How loud is it when they start to distort?
  5. #15
    Dec 2005
    I had 2 wires that looked similar mixed up, i got it working now, the crackle noise is my 2 front speakers are blown gonna replace them both and I'll be all set. thanks for again walky you been a good help. peace
  6. #16
    Nov 2003
    Olympia, WA
    www.neons.org they will have answers to any neon related question you can think of. Check the forums there.
  1. Installing CD DECK (Pontiac Grand AM 2003)
    By _quake in forum Car Audio
    Last Post: 01-15-2006, 11:04 PM
  2. Custom log parsing automation…
    By xcntrk75 in forum Software & Software Development
    Last Post: 05-11-2005, 03:19 PM
