Results 1 to 10 of 16
Thread: I need help installing a CD/MP3 deck on my 97 Neon
    Dec 2005
    I'm a noob and this is my first time installing a radio on any car. I have the speaker wires hooked up 2 front and 2 back. My trouble is installing the power cable and negative cable and also the memory cable. The deck I got has a red wire that says 9turn on +ACC) and a yellow cable that says (Must be connected to battery + 12V) I don't have a specific wire reference for the neon's factory wires but a general pdf file I downloaded says;
    (12Volt battery pink color or pink w/white stripe) and another saying (12volt Ignition wire red w/white stripe) with this info could anyone tell me which ones match up? I did get the deck on once then I blew the radio fuse. I replaced the fuse but I have never been able to get the deck back on.
    PS: if anyone has a Neon factory specific guide for installing a radio, please hook it up, thanks
    Jun 2004
    Rochester
    Turn-ON/ACC+(RED) ->> Ignition (Red w/White Stripe)
    Battery(YELLOW) ->> Battery (Pink or Pine w/White Stripe)
    I'll double check those colors and get you a wiring diagram later.
    Peace.
    Constant Bitrate Legarcondemerde's Avatar
    Jul 2005
    The Biggest Little City
    AHHH! Go spend the extra few dollars and get a wire harness to adapt to your car. It'll be worth it and save you lots of headaches.
    Jun 2004
    Rochester
    I would absolutely recommend a harness adapter. So clean and easy, thats the way I like it.
    Here is the diagram if you need it.
    97NeonRadio.pdf
    And yes, those colors are correct.
    Pink for battery.
    Red-White for ACC.
    Good luck.
    Dec 2005
    Walky thanks, that diagram seems a bit confusing but I'm going to look at it longer.
    So a wire harness from like walmart would illiminate any cutting or wire connecting, it would basicaly just snap on?.
    Constant Bitrate TyBong's Avatar
    May 2005
    Rhinelander, Wi
    snap on to the car yea. you will still need to wire the harness, but alot easyer if you dont chop up your car's wiring. I think you can get ones specificly for your deck and car at some shops, but those are spendy, too much of a hedache to find. Just go with the 7$ wal*mart ones.
    MORE COWBELL.
    Dec 2005
    i already cut the factory wires, next time I'll do it that way.
    May 2005
    Rhinelander, Wi
    Quote Originally Posted by Mic4
    oh well
    MORE COWBELL.
    Dec 2005
    Ok I did what you said and I still get nuthing. I tested the wires for continuity and only the red w/white stripe gave me some voltage. I also noticed a fuse is burned a 4A fuse slot 12 says Illum lamp or lights, I'm wondering if that can be the problem?
    here is a pic of the wiring.
    http://img134.imageshack.us/img134/7...ture0028oh.jpg
    Jun 2004
    Rochester
    That looks a little dangerous.
    It appears that some of those bare wires in your dashboard (like the illumination wire) got shorted to ground for a time and that is probably what caused your illumination fuse to blow. I would guess your dash lights aren't working anymore, right?
    I would suggest disconnecting the car battery when you work on this stuff, and get some insulation on every wire that you won't be using, such as the illumination wire. Electrical tape will work for this. Then use the diagram posted above to connect the appropiate wires. From the picture it looks like you have the right wires.
    Get everything connected and double check it. Re-connect your battery and check all of your fuses.
    Your battery voltage from the car (the pink wire) should be at 12 volts all the time. If it is not then Fuse #13, a 10A, needs to be replaced.
    I can help you figure out the wiring diagram if you need.
    Good Luck.
  1. Installing CD DECK (Pontiac Grand AM 2003)
    By _quake in forum Car Audio
    Last Post: 01-15-2006, 11:04 PM
  2. Custom log parsing automation…
    By xcntrk75 in forum Software & Software Development
    Last Post: 05-11-2005, 03:19 PM
