With phantom center...yes (just read the title...sorry if this doesn't answer your question).
I wanted to make sure that it was possible to run my stock speakers on my 2002 Trailblazer (two front, two front tweeters, and two rears) on a 4 channel amp, and still get a phantom center going (either thru the amp itself or software) and get surround sound for watching DVD's on my Carputer....
Am I wrong? Or is something more involved....
Note that I am just making sure before I buy is all... I have searched, but nothing this particular came up. So, just making sure
TIA
Carputer Progress
[||||||||||] 100%
Finally Installed!!
Everything is in the car and working.
I painted the cilpboard mount and it looks good.
Shutdown/Startup is working excellent!
View My Progress Here
PostCount++
- SrCsTc's Bezel
- Alpine W200/H701
- ED Nine.2X
- OZ Matrix Elites
- ED Nine.1
- Idmax 12's
ONLY if the 4ch amp has separate inputs for front and rear speakers. Just from what I've seen they just use one set of inputs to feed all 4 channels so in that case you won't be able to do true surround sound.
Nick
'99 Ford Escort ZX2 CarPC <-- RIP Feb '07
2006 Chevy Equinox LS (Current Project)
**VIA EPIA PD 1ghz Mobo, OPUS 150, 7" LinITX LCD touchscreen, 512 Ram, 60Gig HD, DLink Bluetooth, Belkin 802.11g wireless,
THis is actually never the case...i have personally used around 6 or 7 different 4 channel amps and they've all had seperate inputs for front and rear...left and right. Only the jl 300/4 had the OPTION of using the front inputs as rear inputs (to save you from running an extra set of cables), but generally they will have seperate inputs.Originally Posted by nkotch
Like i said....it's possible only if your soundcard supports phantom center.
PostCount++
- SrCsTc's Bezel
- Alpine W200/H701
- ED Nine.2X
- OZ Matrix Elites
- ED Nine.1
- Idmax 12's
Yeah, they wouldnt call it a 4 channel amp, if it had 2 channels...
^^^ nicely put...i was trying to say that...lol
PostCount++
- SrCsTc's Bezel
- Alpine W200/H701
- ED Nine.2X
- OZ Matrix Elites
- ED Nine.1
- Idmax 12's
Excellent, thanks guys for the input. I apreciate it![]()
Carputer Progress
[||||||||||] 100%
Finally Installed!!
