Results 1 to 8 of 8
Thread: i want to install AMP AND SUBS IN MY 03JETTA
    May 2006
    i bought a 650 watt amp and 2-12" subs and all the wires and everything for my 2003 jetta with the monsoon system in it with the amp alretty in the trunk.... i wanna install MY amp and subs.... i was wondering how would i do this? what would i have to do? please i need answers!! thanks!! -nick
    Constant Bitrate Legarcondemerde's Avatar
    Jul 2005
    The Biggest Little City
    Use a line out converter connected to the rear speaker leads on the factory amp, which should be on the bottom side of the rear deck. Run power to driver's kickpanel, there is a large junction box there with a 4ga wire that runs to the battery. You can connect the power wire there. The remote line needs to be connected to a switched source of 12v. That's it.
    May 2006
    maybe some pictures anybody?! so i can get a visual!
    _
    Mar 2004
    Little Elm, Texas
    this isn't exactly the best place to ask for such specific advice like this
    try a dedicated car audio forum
    or better yet, try searching the net, there are about a billion how-tos out there
    Jan Bennett
    Raw Wave tj!2k4's Avatar
    Oct 2004
    Quote Originally Posted by yayareapimp69
    some acid, shrooms, or e should do the trick.. check with your local street pharmacist.
    Variable Bitrate 3g Jester's Avatar
    Nov 2005
    when i started off with cars i knew NOTHING about car audio. NOTHING. but then i used the internet and learned all i needed to know. that and find a frined whos done it before. he could help you with a clean install and tips and tricks. do reasearch. do it right!
    Low Bitrate snoopdan's Avatar
    Aug 2005
    Louisville, KY
    I compete nationally with my setup in my jeep, and I have plenty of time on my hands to help you out on any questions or advice.... feel free to hit me up on AIM with the user name "snoopdann" .... that goes for anyone!
    MECA Car Audio Judge
    _
    Mar 2004
    Little Elm, Texas
    what's so ghetto?
    Jan Bennett
  1. using a 1 ohm amp to power 2 ohm subs?!
    By atlantamane in forum Car Audio
    Last Post: 10-27-2008, 02:42 AM
  2. Amp running hot...??
    By Emerica2843 in forum General Hardware Discussion
    Last Post: 02-08-2006, 06:40 PM
  3. Replies: 5
    Last Post: 12-05-2005, 11:12 AM
  4. Help hooking up subs and amp? Need advice...
    By jedi7001 in forum Car Audio
    Last Post: 05-17-2005, 02:28 AM
  5. FS: 2 mtx 10 inch subs and 400 watt amp with box
    By xdjxklusivex in forum Classified Archive
    Last Post: 02-25-2005, 04:41 AM
