Doesnt really matter too much where you put the fuses physically. Hell in audio competitions they require you to have one master fuse for everything, with an accumulated amount of fusing for all equipment.
What size ANL Fuse should i use? (2 Purple Blocks)
Should i install the fuse closer to the amps or to the distro blocks?
thx
MECA Car Audio Judge
in competition, they require you to have a main fuse within 18 wire inches of the battery, this fuse should protect the wire its self (so it should be within the rating of the wire it is protecting). Then you should also fuse each individual component at it's rating.
See the following for help in deciding fuse size, wire size, and battery size.
and yes, it DOES matter where you put your fuses.
What organization do you compete in snoopdan and what class?
Jan Bennett
MECA street 3 & SQ Stock+ and probbaly now modified with the stuff I did to my Jeep today. I run 4 batteries and its still not enough![]()
very nice!
USACi is trying to get with MECA to do a joint finals with them and IASCA, little rocky at the moment, but maybe it will happen!
Jan Bennett
Originally Posted by Red GTi VR6
god I hope so, finals last year was boring.
whoa! could it be?
New System in progress:
M10k
Phaze TD1500 ~> Seas g18rnx/p
Zapco Ref 500.1 ~ 12" tc-9
Transflective Xenarc
My Car Pc Install
My Boat Pc worklog
