Results 1 to 10 of 15
Thread: What amp for two 12" Kappa Perfects?
    May 2006
    What specific amp should I get to power my two 12" kappa perfect subwoofers? I'd like them to have a pretty solid hit , but I dont need to go crazy with the amp.
    So, honestly, what kind of amp (wattage channel ohms all that) will I need to get these babies jumping?
    Thanks! You guys have helped me a lot, and I can't wait to install all of this stuff!
    Mar 2005
    NY
    might want to try an amp that has the same RMS as the kappas.
    Carputer Progress: Here we go again...
    THE GF THEME
    Genesis has speed
    Genesis has class
    Genesis sent money
    before your a__;)
    Join the fight against carputters. EMAIL ME!
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    can you give some specs like impedance, recommended wattage and budget?
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    May 2006
    1600 watt max, 400 watt recommended rms (I've also read 300 other areas? I'd probably go with 400)
    4 ohm(s) nominal impedence
    Budget of like 100-300, nothing outrageous...
    Dec 2004
    Los Angeles Ca
    you'll need a an amp that can produce 600-800 watts @ 2 ohms. check out the elemental designs website, i think they have something in your pricerange that would fit the bill nicely
    M10k
    My Car Pc Install
    My Boat Pc worklog
    Dec 2004
    Los Angeles Ca
    M10k
    My Car Pc Install
    My Boat Pc worklog
    May 2006
    and 800+ watts at 2ohm will run 2 subs?
    Do I need to be able to channel or anything like that? Like, what exactly will I need in the amp to be able to power both of the subs?
    Dec 2004
    Los Angeles Ca
    i'm not sure what you mean by 'be able to channel'
    you can power as many subs as you want off of 1 set of channels, if that is what you're inquiring about. you just have to know how to wire them to get the impedance (ohm load) that the amp can handle
    what you need to look for is:
    if you are looking at a mono amp (1 chan) it has to be 2 ohm stable and around 800+ watts at 2 ohms.
    if you're getting a two chan amp:
    you'll want to find something that is 400+ watts per chan @ 4 ohms
    your best bet is to find a mono class d amp that is 2 ohm stable (i.e 800 wrms x1 @ 2ohms). it's cheaper then a two chan class a/b that would have the same power (i.e. 400 wrms x2 @ 4ohms).
    just to be clear... the subs are single 4 ohm voice coils? or dual 4 ohm voice coils?
    do you have a model #
    M10k
    My Car Pc Install
    My Boat Pc worklog
    Dec 2004
    Los Angeles Ca
    this is how you'd wire it if it were two single voice coil 4 ohm subs being powered by a mono amp @ 2ohms:
    http://www.cardomain.com/shop/woofer..._svc&x=52&y=13
    M10k
    My Car Pc Install
    My Boat Pc worklog
    May 2006
    The kappa perfects (vq) are 4 ohm (Dual Coil)
    http://www.infinitysystems.com/carau...946_eprint.pdf
    http://www.infinitysystems.com/caraudio/product.aspx?ProdId='KAPPA+PERFECT12VQ'&Ser=KPE&Ca t=SUB
    Those are the specs...
  1. vw mk4 monson amp and another amp
    By colorless in forum Car Audio
    Last Post: 09-05-2012, 10:43 AM
  2. Amp running hot...??
    By Emerica2843 in forum Car Audio
    Last Post: 01-29-2006, 07:29 PM
  3. FS: Memphis Belle Amp & IDQ 12" Sub
    By 97legacygt in forum Classified Archive
    Last Post: 11-16-2005, 06:30 AM
  4. Replies: 7
    Last Post: 10-18-2005, 02:53 PM
  5. Help match me a 10" or 12" sub to my amp please!
    By tbird2340 in forum Car Audio
    Last Post: 07-21-2005, 07:07 AM
