I would go with your first suggestion, one for the cdts, and one for the eu-700's
So i was wondering about how to load my amps while wiring my speakers. The setup; for those of you that dont know. will be an active x-over, two 2-chan. amps (for front stage), a set of cdt cl-41 2-way with passive x-over and a set of elemental designs eu-700 6.5" mid/woofers in each door.
now the question i have is what is the optimal way to wire the amps? should one amp power the cdt's and another amp power the eu-700's -OR- should one amp power the speakers on the right and one amp power the speakers on the left? (i.e. one chan powers the right side cdt components, the other chan; on the same amp, powers the eu-700 on the right side. Then the second amp will do the same on the left side)
I was thinking that the eu-700's would be drawing a lot more power causing the one amp will be working a lot harder then the other.
thoughts, suggestions?
New System in progress:
M10k
Phaze TD1500 ~> Seas g18rnx/p
Zapco Ref 500.1 ~ 12" tc-9
Transflective Xenarc
My Car Pc Install
My Boat Pc worklog
Hey Laserlips, your momma was a snowblower!!
Why do you think that is a better way?
also, rereading that, it may not be clear to everyone what i'm trying to decide between so this may make it a bit clearer-
option A)
-amp 1-
chan 1 powers left cdt cl-41
chan 2 powers right cdt cl-41
-amp 2-
chan 1 powers left eu-700
chan 2 powers right eu-700
-OR-
option B)
-amp 1-
chan 2 powers left eu-700
-amp 2-
chan 1 powers right cdt cl-41
M10k
My Car Pc Install
My Boat Pc worklog
I just figured it would be easier to have an amp powering each set of speakers. lol
...errr...thanks? actually it's pretty much the same amount of work for each, just a slightly different cable configuration (due to the unique zapco balanced output jack) but since i'm making the cables myself it doesn't make a difference.
M10k
My Car Pc Install
My Boat Pc worklog
well, in case anyone is actually going to look at this thread. fyi each chan on the amps have thier own individual gains
M10k
My Car Pc Install
My Boat Pc worklog
