Results 1 to 9 of 9
Thread: Please Help Im New
    May 2006
    Please Help Im New
    ok so i have a JVC KD-6101
    at the moment i am running the front mids and rear mids of the deck but plan to get a 4 channel amp to run them
    now heres the question...
    1 . how do you run a centre channel ...as theres no centre speaker cable ??
    2 . do you have to use the digital out into a equailiser or amp to get the centre channel ...
    Elsewhere
    1. Run your own speaker cable.
    2. No.
    How about the Wiki?
    May 2006
    ok but now how ...cos its got front left and right from the deck harness
    _
    Mar 2004
    Little Elm, Texas
    man - you REALLY need to do some of your own research first.
    I'd recomend starting here first:
    http://www.mp3car.com/vbulletin/the-faq-emporium/
    Specifically the spoon fed thread.
    Jan Bennett
    Jun 2005
    chicago, Illinois
    Unfortunatly with that unit, it is not possible to use a center channel with the current pre-outs that it provides. I would have to guess that the center channel signal was mixed into the front speakers as there are only fronts rears n sub outputs. I would assume that the only way to get the true signal for center channel dts is to use the digital optical ouput.
    your other option for a center channel speaker is to get a small amplifier that you can input the front speaker preouts and can give you a mono (or bridgeable) output that would match the speakers power handling.
    PROGRESS:
    _
    Mar 2004
    Little Elm, Texas
    dood - he's gonna read that and be all.....hu? wha?
    Jan Bennett
    Jun 2005
    chicago, Illinois
    Yeah, Sorry. I tend to over-complicate things sometimes. force of habit with my customers that they want me to explain to them how to do things instead of actually paying for me to do it.
    I'm not trying to confuse on purpose. Hopefully you can understand.
    PROGRESS:
    May 2006
    Mar 2005
    NY
    hehe, how about this: WHY do you want a center channel? Why not keep it simple at 4.1 instead of spending a few hundred for 5.1 for an volume the size of your shower? Do you really think you'll tell the difference?
    Carputer Progress: Here we go again...
    THE GF THEME
    Genesis has speed
    Genesis has class
    Genesis sent money
    before your a__;)
    Join the fight against carputters. EMAIL ME!
