Results 1 to 6 of 6
Thread: Removing a '94 Camry Radio
    May 2006
    Post Removing a '94 Camry Radio
    Ok, I'm trying to remove this radio out of the car. It's a 1994 Toyota Camry LE (Wagon). It has an Anti-Theft Lock, I don't know the code. It's my dad's car but yet he doesn't know either. I heard that you can take out the negative (-) hook-up off your battery and then remove the radio.
    Another problem is actually getting the radio out. There is no removable face-plate, no screws, nothing. I have no idea what to do! Any suggestions?
    In Christ,
    God sent His Son as a sacrafice for our sins!
    This is True Love.
    Low Bitrate KMorphosis's Avatar
    Aug 2004
    Faw from heyar...
    Its really easy to take the radio out of the Camry. THere is a U-shaped trim that surrounds your stereo and probably door tray. Grab a flat head screw driver, put some tape on the tip and then you will slide it under the trim. Gently pop it up and then do it at the other side on the bottom. It will pop off easy enough. Then your radio is held in by 4 screws. Thats all it takes. You will slide the radio out and then disconnect the cables on the back.
    May 2006
    What about the Anti-Theft Lock? If I removed it won't the car be inoperable?
    This is True Love.
    Raw Wave EsKALad's Avatar
    Jan 2005
    Chicago, IL
    No Dude That Means It Wont Work Without A Code When U Plg It Back In
    i got dat ***** sittin on 22s! SUPERMAN EDITION!
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    can't you get the code from the dealer if you give them the vin of the car?
    New System in progress:
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    Dec 2005
    I'm unsure but just taking it out and replacing it should be fine I think the whole security thing is if someone tries to use that radio somewhere else it won't work so why would they steal it. But stock radios all suck so why would someone want to use it somewhere else anyway thats security enough. However, I know someone with a 99 camero that removed his radio and his car wouldn't start never had that problem on my install in a 95 accord, 2002 grand prix, or a 99 calvarier. I think the guy was just dumb and messed up some other stuff though.
  1. Class 2 Data Bus
    By owenjh in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 10-09-2008, 04:34 AM
  2. XM Satellite Radio to Unveil XM Advanced Services at 2006 Consumer
    By Will Albers in forum General MP3Car Discussion
    Last Post: 03-27-2006, 09:49 PM
  3. wintv radio not launching when i press radio
    By dnkyntz in forum RR Bug Tracker
    Last Post: 12-23-2005, 02:49 AM
  4. Replies: 0
    Last Post: 12-15-2005, 10:15 AM
  5. Removing FM / XM Radio Button
    By 65Stang in forum Media Engine
    Last Post: 05-16-2004, 09:49 PM
