Results 1 to 8 of 8
Thread: 1998 Corvette Bose System Questions
    Low Bitrate Epon's Avatar
    Oct 2005
    I know that the factory amps in the Vette runs at 1-2 ohms and most aftermarket speakers are @ 4 ohms. Now, I'd really rather not replace the headunit, so is there anyway I can somehow wire each speaker up so the amp output is seeing 2-ohms instead of 4? And other than a power cut (volume will decrease obvs from the impedence being lower), if I just threw new speakers in there, will **** explode?
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    you can replace the factory 'twiddlers' with 3.5" coaxials and the rears with 5.25 or 6.5 depending on if you have a vert/frc or coupe. the 'subs' you'll be stuck with though
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    _
    Mar 2004
    Little Elm, Texas
    man - I so hate factory 'premium' audio systems, always causing so many problems, and always cost way more than a decent aftermarket set-up.
    Jan Bennett
    Apr 2006
    Quote Originally Posted by Red GTi VR6
    i hate them with a passion. for half the price of what they cost u can get a system that will blow any bose system out of the water.
    _
    Mar 2004
    Little Elm, Texas
    ****ers, can't even get a car without a radio in it....hahahaha
    Jan Bennett
    Dec 2004
    Los Angeles Ca
    hey epon,
    here is a c5 audio faq i wrote up:
    http://forums.corvetteforum.com/show....php?t=1117959
    it'll give you all the answers you should need
    M10k
    My Car Pc Install
    My Boat Pc worklog
    Oct 2005
    Thanks guys, thsi stuff really helps. I got one quick question left though. Instead of getting 3.5's to repalce the tweaters and keep the subs, can I remove both the tweaters and subs and get 6.5 coax's to shove into the sub's holes and wire them up with the tweater's wiring? That'd be more convienent for me right now. Eventually I plan on just rewiring the damn thing, so I'd prefer having the speakers I want now.
    Dec 2004
    Los Angeles Ca
    those twiddlers aren't getting a full signal. you'd have to get an external amp. your best bet is to go the 3.5" route for now. Coax's in our cars aren't optimal, it sets the tweeter very low where your knee muffles most of the highs.
    M10k
    My Car Pc Install
    My Boat Pc worklog
  1. A few observations in OS and why I'm now using Windows 2003...
    By Mastiff in forum Software & Software Development
    Last Post: 01-21-2004, 09:11 AM
  2. Replies: 1
    Last Post: 10-07-2003, 01:53 PM
  3. Replies: 9
    Last Post: 10-07-2003, 08:19 AM
  4. general questions about these systems
    By Draco in forum General Hardware Discussion
    Last Post: 03-30-2003, 09:17 PM
  5. realmagic hollywood plus and dvd questions
    By nyconx in forum General Hardware Discussion
    Last Post: 12-17-2000, 11:42 AM
