Results 1 to 8 of 8
Thread: S/B Live Problem
    Apr 2006
    S/B Live Problem
    I've finally gotten my project into my car and have a problem with my S/B live card that I'm not sure how to fix. Every problem I've encountered I've been able to fix due to and so I find myself spending hours learning here but unfortunately I can't find anyone with this problem....
    I have my amps hooked to the "turnon" on my m2-atx and it works fine, but my S/B live does not turn on until after windows boots. Thus, I'm hearing a crazy amount of ground loop noise (I have an isolator running from the S/B live to the amps so it's gone once the card is on) and I get a nasty pop when the card kicks on. I guess the solution would be to rig the card to turn on with the amps. Is there a way to set the software to turn on at startup or a way to wire the S/B Live to kickon with the m2-atx "turnon"? How do people with external cards get around this?
    It's amazing that no matter how cool it is once it's on, no one will forget that first 15 seconds of crap.
    Thanks a bunch.
    Apr 2006
    Oh I guess it's also customary to list what I have in it:
    ASUS P4B
    Pentium 1.4GHz
    528 SDRAM
    Maxtor 40GB
    USB 2.0 Hub
    Lilliput 7" w/touch
    M2-ATX
    DVD - slotload (not in yet, trying to figure out best way to hook it up)
    Bluetooth Adapter - have it but need to see how ****ed off I'll get trying to get my Treo to work - since after numerous threads i've come to the conclusions it's probably not going to work
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    how about a delay on the amp turn on lead?
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    Apr 2006
    How would you go about creating a 15sec ish delay?
    Jun 2005
    chicago, Illinois
    I wouldnt use a pulse timer in that situation, due to the fact that it's a temporary activation. I could explain how a DEI 528t pulse timer could be usefull in this situation, but i'd probably over complicate it.
    There is a part PAC tr-7, that might be good because its totally programmable:
    " Low voltage trigger. Gives you +12v output from headunits that do not have a remote output."
    PROGRESS:
    Apr 2006
    Thanks. I think my best bet may just be putting a kill switch on the turn on. That way I can kill it for the first few seconds and if I forget to turn it off they would kick off when I kill the engine. Also handy if I forget that I came home blasting the music and get halfway down the block at 7 in the morning when Snoop Dogg "Snoops upside my head" at 120dB. Thanks for the input.
    Dec 2004
    Los Angeles Ca
    get the delay, you dont want to have to flip a switch everytime you get in the car...ANNOYING!!! i think you may be able to make a simple one with a cap and a resistor.
    M10k
    My Car Pc Install
    My Boat Pc worklog
    Maximum Bitrate albysure's Avatar
    Dec 2000
    pittsfield, ma.
    go to http://www.davidnavone.com and get his adjustable 12v timer. thats what i use to avoid the turn on thump from the computer
    heres the item:
    http://www.davidnavone.com/detail.asp?PRODUCT_ID=N-66A
  1. Not your typical flicker problem
    By JPuma in forum LCD/Display
    Last Post: 05-30-2007, 10:28 AM
  2. had an all day (9 hr) problem at work....
    By wizardPC in forum Off Topic
    Last Post: 10-20-2005, 12:50 PM
  3. audio problem
    By tiburonputer in forum General Hardware Discussion
    Last Post: 08-11-2005, 04:58 PM
  4. YAOP (yet another Opus problem)
    By Frankino in forum Power Supplies
    Last Post: 06-19-2005, 12:17 PM
  5. power on problem ??? help please anyone
    By Pingo1969 in forum Power Supplies
    Last Post: 04-07-2004, 08:47 AM
