Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: Subless audio?
  1. #11
    Jun 2005
    Michigan
    Quote Originally Posted by chuyler1
    Is it a Mazda3 hatch or sedan? Both models have 5x7s in each door but you can also fit 6.5" speakers by using a custom baffle.
    When planning an IB (infinite baffle, ie no enclosure) install you want to choose the largest woofer that will fit.
    I have the sedan. I had forgotten about the Mazda3 forums, so I'll probably head over there to look at installs, but I remember the forum being rather clueless last time I checked in.
    At risk of getting hit with search or google, how does IB usually work? I assume you want to use your whole trunk as the 'enclosure', so how/where do they mount? Most sub boxes I've seen are just tossed into the trunk, but dont I want some kind of baffle going into the cab?
    MII-12000 / Ampie / Lilliput 7" / BU-355 / PicoPSU / uSDC
    Currently: Enjoying the setup, but always contemplating my next move...
  2. #12
    Newbie jizzajam's Avatar
    you can fit a ton of speaker in your door as long as you're willing to do come hacking.
    heres what I did
    lots of deadening, sounds great. still have a sub tho :q
  3. #13
    Constant Bitrate chuyler1's Avatar
    Feb 2006
    Massachusetts
    IB: Basically you find a way to separate the front of the subwoofer from the rear of the subwoofer by using the trunk as an enclosure. You can mount the subs under the rear deck and use existing holes to get the bass into the cabin. You can also use the cargo pass-through hole by carefully creating a baffle that spans the entire opening and seals off the front of the subs so they are forced to push air through the rear seat.
  4. #14
    Maximum Bitrate Sidewalksalvage's Avatar
    Mar 2006
    NJ/RI
    Best case would be to mount them on the deck, again biggest ones you can find (but dont jip out on quality, ive found that smaller, better quality ones are better than huge cheap ones...) This way your trunk is the enclosure. Definatly look into sound deading material like dynamat to line the trunk, this way the most sound goes into the cabin rather than out the trunk...
    Brown 2010
  5. #15
    Low Bitrate Mandos's Avatar
    Sep 2005
    Coralville, IA
    cone area of a EU-700 (6.5" woofer w/ 3/4" surround) = 20cuin x 2 = 40cuin
    cone area of a ID8 (8" woofer w/ 1/2" surround) = 38.5cuin
    cone area of a ID10 (10" woofer w/ 1/2" surround) = 63cuin
    I was considering the EU-700s for an IB install in my Dad's truck but after getting past the hype they seem to be more a novelty than a practical solution. Sure you can install them in a stock 6.5" door location but you need to spend upwards of $100 in sound deadening material to get them to sound decent and still they won't be as loud as a single 8" in a sealed enclosure. They also have a fairly deep mounting depth requirement. Not as much as an 8" but still more than the average door has room for.
    Actually...official spec on sd for the 700's is 17.75 inē 2 700's have just slightly less air movement than a single 8...but to almost anyone would sound identical.
    They are a practical solution for people that have odd space requirements....and they really do sound good. Granted, a single one ported makes for a HUGE box that defeats the purpose of a tiny sub, but it sounds awesome.
    As for in a door, yeah, totally impractical. That said, I'm doing it eventually, just need to get the 32 in the hatch first. My doors are already prepped for it and can fit them, only modification was extra deep spacer and cutting the trim ring off the back of the plastic panel.
    Chris Schempp
    Elemental Designs
    Scion tC in progress
  6. #16
    Jul 2001
    Rear deck mounted subs is fine, just dont go trimming away to much metal to squeeze in a pair of 12's or what not without reinforcements, the rear deck is a very structural part of any car.
  7. #17
    Mar 2006
    NJ/RI
    yes and no...it depends on the car.. I cant vouch for a mazda3 but i do know in my friends Shadow its basically a piece of cardboard...where as my camry its a huge reinforcement. Check how your car is set up. Since they have made a hatchback version...im not sure its that structurally importand... BUT CHECK FIRST before you go cutting away. Also, if it is a piece of cardboard, you might want to replace it with mdf or another more sturdy structure, a sub may blow it apart otherwise...
    Brown 2010
  1. OEM Navigation Connectors
    By Mr Castulucci in forum General Hardware Discussion
    Last Post: 07-20-2010, 06:25 PM
  2. timeouts and bluetooth audio randomness
    By numbers in forum PhoneControl
    Last Post: 01-09-2006, 04:44 PM
  3. designing audio system
    By 1DeepG in forum Newbie
    Last Post: 06-29-2005, 09:48 PM
  4. Audio problems, Epia Sound, and FAQ stuff
    By gothate in forum Newbie
    Last Post: 06-16-2005, 05:04 PM
  5. XMDirect Digital Audio Project ?
    By Retsaoc in forum General Hardware Discussion
    Last Post: 10-11-2004, 10:26 PM
