Results 1 to 10 of 17
Thread: Subless audio?
    Jun 2005
    Michigan
    Subless audio?
    Im driving a Mazda 3 and the stock speakers just arent cutting it. Im currently using an XM roady and my MII with mobo sound (which doesnt help), but I just dont get any decent sound. I want to ditch the HU and get an amp with some speakers, but I need to know...can you still get goodsound without a sub? Are there other solutions to moving the bass out of your door speakers that dont involve a big freakin box in my trunk? I want to preserve 100% of my trunk space here, but dont want all my songs to sound like mush...
    MII-12000 / Ampie / Lilliput 7" / BU-355 / PicoPSU / uSDC
    Currently: Enjoying the setup, but always contemplating my next move...
    FLAC Jahntassa's Avatar
    May 2005
    Conyers, GA
    You can get 'decent' sound out of a good set of aftermarket speakers, a decent headunit, and a good amplifier. But you probably won't be able to perfectly replace a subwoofer with it. I've seen I think a Clarion small box sub that you could probably stick somewhere. The 'woox' maybe?
    May 2006
    hey,, depends on your prefrences of big bass.... u want alot go with a sub.... and what speakers do you have.. i was thinking about getting a sub but i just changed my stock speakers to some polks... and it sounded fine to me.. Although i have 2 6x9's... and thats what gives me the decent bass.. if im correct mazda3's have 6 1/2's all the way around.. so eh.. sub it up..
    Maximum Bitrate Sidewalksalvage's Avatar
    Mar 2006
    NJ/RI
    If you are looking for bone rattling bass....there will be no speakers that will cut it. That said. If you get nice speakers, especially composites. The woofer with a Hz cut off at say 500 and then the a mid range smaller speaker for 500 to say 1000Hz and then toping it off with a nice tweeter for the rest (these are estimated Hz ranges, best to check it out in more detail...but for the sake of argument) This would creat a nice sound stage. See the woofer will handle only a bit more than the a sub would and therefore give you clean bass.
    Brown 2010
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    you could try some elemental design eu700's in an infinate baffle setup in the rear. feed each of the 150 wrms and you should have some nice bass
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    Constant Bitrate chuyler1's Avatar
    Feb 2006
    Massachusetts
    Is it a Mazda3 hatch or sedan? Both models have 5x7s in each door but you can also fit 6.5" speakers by using a custom baffle. I'm not sure whether the sedan has openings in the rear deck for speakers since I don't own one. If there are openings I'm going to guess that they are for 5x7 speakers.
    When planning an IB (infinite baffle, ie no enclosure) install you want to choose the largest woofer that will fit. The EU-700s are nice little subs but you'd need two of them just to equal the output of a single 8". Its all about cone area. Forget that the openings are only 5x7. Scott Buwalda piped 3 12"s through his 6x9 holes and managed to get a flat RTA response down to 20Hz. So if you can physically mount 10"s under the rear deck...do it! Also make sure you add adequate sound dampening material to the rear deck such as RAAMmat (www.raammat.com).
    However, maybe you should focus on getting more power to your front speakers and upgrading to a nice set of separates (aka components). You'd be surprised how much bass some new speakers can put out compared to stock.
    If you have the hatch model...this is one way to get some bass into your car without taking up additional space:
    http://www.mazda3forums.com/index.php?topic=33566.0
    Dec 2004
    Los Angeles Ca
    Quote Originally Posted by chuyler1
    actually they (two) are supposed to have the output of a single 10"
    M10k
    My Car Pc Install
    My Boat Pc worklog
    Feb 2006
    Massachusetts
    cone area of a EU-700 (6.5" woofer w/ 3/4" surround) = 20cuin x 2 = 40cuin
    cone area of a ID8 (8" woofer w/ 1/2" surround) = 38.5cuin
    cone area of a ID10 (10" woofer w/ 1/2" surround) = 63cuin
    I was considering the EU-700s for an IB install in my Dad's truck but after getting past the hype they seem to be more a novelty than a practical solution. Sure you can install them in a stock 6.5" door location but you need to spend upwards of $100 in sound deadening material to get them to sound decent and still they won't be as loud as a single 8" in a sealed enclosure. They also have a fairly deep mounting depth requirement. Not as much as an 8" but still more than the average door has room for.
    Dec 2004
    Los Angeles Ca
    i stand corrected, never did the math...actually still didnt do the math...dont really care much either
    here is an insteresting read on it though:
    http://www.icixsound.com/vb/showthre...ghlight=eu-700
    M10k
    My Car Pc Install
    My Boat Pc worklog
    Feb 2006
    Massachusetts
    He's got 4 in a fairly large ported box. That's a far cry from 2 in an IB setup. Now if you are shooting for SPL then I'm sure the EU-700 can hold its own for what its worth. But when you are talking about SQ you need something that can efficiently play below 30Hz.
  1. OEM Navigation Connectors
    By Mr Castulucci in forum General Hardware Discussion
    Last Post: 07-20-2010, 06:25 PM
  2. timeouts and bluetooth audio randomness
    By numbers in forum PhoneControl
    Last Post: 01-09-2006, 04:44 PM
  3. designing audio system
    By 1DeepG in forum Newbie
    Last Post: 06-29-2005, 09:48 PM
  4. Audio problems, Epia Sound, and FAQ stuff
    By gothate in forum Newbie
    Last Post: 06-16-2005, 05:04 PM
  5. XMDirect Digital Audio Project ?
    By Retsaoc in forum General Hardware Discussion
    Last Post: 10-11-2004, 10:26 PM
