Results 1 to 5 of 5
Thread: How can I fix this...
    May 2006
    I was just wondering if I could solder speaker wires together, or any other method of easily attaching the wires back together.
    I ask because I purchases and recieved some used infinity kappa rear speakers, and when I got the box, it looked like a football team had used it for a ball one practice. Now the speakers were in pretty good condition, but one of the tweeters on the speaker had broke off. To my knowledge, the tweeter itself is fine, but broken off from the speaker, and it just needs to be put back on.
    THe problem is that the wires are so small, it would be impossible for me to attach the wires again and still be able to glue it back to the speaker. The pictures should help...
    any suggestions? it's used so asking for a new one really wont result in much and other than this the speakers are in good shape and sound great
    Newbie blazinaspire's Avatar
    May 2006
    guelph otario canada
    extend the wires a bit by soldering then and use small heat shrink and then just tuck the extra wire back under the tweeter were that pipe goes through the midbass drivers voice coil
    May 2006
    Quote Originally Posted by blazinaspire
    small heat shrink?
    Constant Bitrate fooshizn1x's Avatar
    May 2005
    714 - Socal baby!
    heat shrink tubing is what he is refering to. It has many uses, mostly used when you solder two wires together, the tubing is first slipped over and down one of the wires, then you solder the wires together, then you slide the tubing over the freshly soldered wires, heat it up with a heat-gun, lighter, etc, and it shrinks to cover the wires snugly and neatly, far superior to just taping them with electrical tape.
    here is what it looks like
    http://www.acehardware.com/product/i...ductId=1292814
    Sell me your stuff.. please see what i'm looking to buy
    http://mp3car.com/vbulletin/showthread.php?t=75182
    May 2006
    yea there is what looks like a lot of room in there, so just make longer wires and then tuck them into there
  1. IG Nag screen/ embed issues FIX how to
    By liquid_smoke in forum RR Skins
    Last Post: 06-03-2006, 03:35 AM
  2. Neocar External Application Bug Fix!
    By reddeath30 in forum NeoCar Media Center
    Last Post: 04-07-2005, 09:25 AM
  3. How to switch to sirf from nmea & push to fix mode
    By qbee in forum Software & Software Development
    Last Post: 03-07-2005, 07:59 PM
  4. Think I foubd BUG with map monkey and media car
    By cdevelasco in forum MM Bugs
    Last Post: 02-02-2005, 10:52 PM
  5. Palm Battery drain fix
    By Loftus in forum General Hardware Discussion
    Last Post: 05-01-2002, 09:57 AM
