Page 1 of 8 12345678 LastLast
Results 1 to 10 of 77
Thread: I don't know how to wire an amp, am I stupid?
    May 2006
    Calgary, Alberta
    I've got a complete stereo wired up in my car, it's easy to do. But once I switch from my regular head unit flip out screen to an actual VGA screen, then how do I hook it up? Where does the remote lead wire go? Where's the subwoofer out cable? And where do the speakers wire up to? I just thought of this, guess I should have considered it before I got the computer.
    Ampie Case
    256 MB DDR2 PC5400
    Xenarc 700TSV - VGA Monitor
    Intel D945GCLF Motherboard
    M2-ATX-HV
    2005 Honda Civic
    _
    Mar 2004
    Little Elm, Texas
    have you done any searching?
    I distinctly remember another thread regarding something very similar.
    Jan Bennett
    Maximum Bitrate 3onDubs's Avatar
    Aug 2005
    Anaheim Hills, Ca
    yes and no
    PostCount++
    - SrCsTc's Bezel
    - Alpine W200/H701
    - ED Nine.2X
    - OZ Matrix Elites
    - ED Nine.1
    - Idmax 12's
    May 2006
    Your screen might not have those connections on it. What kind screen ?
    Mar 2006
    Colorado, but Canadian!
    Remote wire lead to amps: On M2-ATX there is a header pin for this. Even had "anti-thump"
    Subwoofer: The black connector on the sound card when set to 4.1/5.1 sound through XP.
    Speakers: Use the blue and green and maybe if fancy red/yellow sound card connectors.
    To hook up the speakers and subwoofer, use 1/8" to RCA adapters, send to amp, and from amp to speakers.
    Has been discussed many many many many many times.
    May 2006
    Calgary, Alberta
    What if I have the M1-ATX? Onboard sound? M10000 motherboard? I don't have a screen yet, I have to buy one.
    Ampie Case
    256 MB DDR2 PC5400
    M2-ATX-HV
    2005 Honda Civic
    _
    Mar 2004
    Little Elm, Texas
    the screen doesn't matter, and what are you asking exactly?
    how to wire it all up!?
    read the directions
    Jan Bennett
    Mar 2006
    If you have the M10000, then use the green and blue for front and back speakers. Each port carries 2 channels, so you have 4. Front-Left, Front-Right on 1, and Rear-Front, Rear-Right on the other. Then through the M10000 driver software you can configure the Microphone (red) port to be another speaker out. Set to subwoofer and run that to your subwoofer amp. The red port is mono, so good for a subwoofer. I'm not sure if the M1 has the remote on, look in the book. If you can't find it I will try.
    May 2006
    Calgary, Alberta
    Wow, there's a lot more thought to this than I considered. I wish I hadn't ordered it all so hastily. So here are my final questions, I don't think they're too noobish, I do know a lot about car audio, just nothing about circuit boards.
    My PSU is 90 watts, can it take all this, GPS, bluetooth, Wi-Fi, and a screen? Plus other miscellaneous USB stuff like a card reader or whatever? Damn, should have gotten the M2-ATX for $20 more.....
    So let me get this straight....
    The motherboard connects to the amps via 4 speaker out ports and the microphone port. Then one amp to the sub and one amp to 4 speakers.
    The PSU has a remote lead that goes where? It also has power to the battery, and ground to the chassis.
    The amps have a remote lead that goes where? They also have a power to the battery and ground to the chassis and my mono sub amp also has a wire to a remote bass knob but that's irrelevant.
    Each speaker has a ground as well I guess?
    The screen has a remote lead, where does this go? And they have power from the PSU or motherboard? And ground to the board I guess? And USB for touchscreen? What about a remote?
    Ampie Case
    256 MB DDR2 PC5400
    M2-ATX-HV
    2005 Honda Civic
    May 2006
    Calgary, Alberta
    I'm trying to get it all figured out so I can do mine and then I'll post a DIY on how to wire up the entire system.
    Ampie Case
    256 MB DDR2 PC5400
    M2-ATX-HV
    2005 Honda Civic
  1. how to wire amp turn-on lead?
    By emdzey01 in forum Power Supplies
    Last Post: 02-03-2006, 12:48 PM
  2. Amp acc line = psu ignition wire?
    By 3onDubs in forum Power Supplies
    Last Post: 10-25-2005, 05:35 AM
  3. AMP wont turn ON!! HEELP!
    By pdjafari in forum Car Audio
    Last Post: 10-15-2005, 08:43 PM
  4. Morex 60W car kit - 4 or 6 wire?
    By MVShibui in forum Power Supplies
    Last Post: 05-09-2005, 02:28 PM
  5. Replies: 2
    Last Post: 04-24-2005, 07:01 PM
