Results 1 to 3 of 3
Thread: Ground Loop Isolator
    May 2006
    There is interference playing out of my subwoofers. Everything from revving the engine to ejecting a CD.
    My Set-Up: 3 kenwood 10" subs bridged to a 1200 watt sony amp, connect through a capacitor that is grounded to the car.
    When put the ground loop isolator between the RCA cables and the amp, the subs are muted and no sound comes out at all. The same happens when i connect it through the back of my head unit.
    Whats going on here?
    _
    Mar 2004
    Little Elm, Texas
    does the isolator have a small ground wire coming off of it?
    try grounding or not grounding it.
    Jan Bennett
    Falls Church, VA
    Either the amp or headunit is not ground properly. My guess is that the headunits preamp output's ground is fried.
    Plug your ipod into the amplifier inputs, get sound?
  1. Re-Ground HU or Ground Loop Isolator?
    By Incinorator in forum Car Audio
    Last Post: 04-20-2006, 08:52 PM
  2. FS: Ground Loop Isolator
    By djXternal in forum Classified Archive
    Last Post: 03-08-2006, 09:47 AM
  3. Best Ground Loop Isolator
    By Telos in forum Car Audio
    Last Post: 07-22-2005, 11:36 AM
  4. I tried everything, can't get rid of this ground loop
    By intense in forum General Hardware Discussion
    Last Post: 07-10-2005, 09:58 AM
  5. ground loop isolator help
    By digital chaos in forum General Hardware Discussion
    Last Post: 03-11-2001, 02:38 AM
