Results 1 to 5 of 5
Thread: EQ Software.
    Maximum Bitrate Fusion-One's Avatar
    Dec 2002
    Montreal, Quebec
    EQ Software.
    Is there any software/players/frontends that allow for EQ adjustments on a per channel basis? Given that most soundcards these days are 5.1(6ch), and for stereo reproduction only 2 are needed I see the potential for an accurate computer based crossover/eq.
    If you took a 5.1 sound card, and sent 2 channels to the tweeters, 2 to the mids, and 2 to the subs.. you could eliminate all hardware crossovers and EQs by adjusting each channel's EQ settings through the software.. and in software, extra sliders are cheap. There is really no reason you couldn't have 100 of them straight along the spectrum.
    If this software doesn't exist.. would there be interest in it, or do most people prefer hardware solutions? Given the speeds of today's CPUs, I can't think of any reason that a good quality software based audio processor couldn't match the quality of the hardware based solutions. If I make this, it will probably be a fairly simple standalone player, however, the ideal solution would be for it to function as a winamp output plugin so that it could be used in many different frontends.
    Gimme some feedback,
    -Jared
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    sort of related:
    1/3 Octave Software EQ
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    Constant Bitrate chuyler1's Avatar
    Feb 2006
    Massachusetts
    If you are looking for a project, how about designing a player that incorporates a 30-band eq per channel along with 6/12/18/24db fully adjustable high-pass and low-pass crossovers per channel. Oh, and throw some time alignment in there while you're at it.
    Low Bitrate snoopdan's Avatar
    Aug 2005
    Louisville, KY
    Quote Originally Posted by chuyler1
    lol, the time alignment would be the easiest part!
    MECA Car Audio Judge
    Low Bitrate kingeorge36's Avatar
    Mar 2004
    This thread and product is right up your alley!
    Directdvd 6 HD possible in car EQ???
    SUVPUTER:
    AMD~SILVERSTONE~AUDIO CONTROL~BOHLENDER GRAEBENER~IMAGE DYNAMICS~ROCKFORD FOSGATE~OPTIMA~STINGER
  1. 1/3 Octave Software EQ
    By Quack in forum Car Audio
    Last Post: 07-18-2006, 03:34 PM
  2. CarPal Bluetooth Module & Digimoto Software....A Very Good Combo..
    By jmciver in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 06-16-2006, 05:08 PM
  3. VST Plug-In support - software EQ
    By Quack in forum FrodoPlayer
    Last Post: 03-31-2006, 11:25 PM
  4. Winamp 2.9x and 5.x EQ.
    By stevewm in forum Software & Software Development
    Last Post: 12-23-2003, 11:17 PM
  5. My numpad controlled custom MP3Car software - need your opinions
    By PorscheMP3 in forum Software & Software Development
    Last Post: 04-11-2002, 11:30 AM
