Results 1 to 6 of 6
Thread: audio system
    May 2006
    lancashire, england
    Question audio system
    hey, im looking for a new sub n amp to go in my 306, £200 is the limit. any suggestions would be great. cheers.
    Newbie blazinaspire's Avatar
    May 2006
    guelph otario canada
    ok according to tdays exchange rate 200 euro is 254.773 USD
    and for that 254.773 you could get a ma audio amp (M700XE ) and one ma audio 12inch sub ( MA12D4 12" )
    you can get 250wrms from each chanel from that amp at 4ohm and just hook up each chanel to each voice coil on the sub ( DVC sub ) and then you will have 500 wrms going to that one sub, and trust me ma audio subs will handle more then they are ratted for, it comes out to 280 or so $ us but save up the 26$ its well worth it, i have 550wrms in my car with one 12 inch sub and my wipers move to the bass slightly, and my box is not even to spec
    here are the links for the two items
    amp
    http://www.sonicelectronix.com/item_6561.html
    sub
    http://www.sonicelectronix.com/item_4085.html
    Low Bitrate kingeorge36's Avatar
    Mar 2004
    Don't forget about the aternator and battery and power wires!
    I reccomend that before buying high power amps and subs. WIthout any of those improvements your a step behind, plus if you want a higher amp or amps for your other speakers in the future you'll have a good alternator and battery that can handle it!
    SUVPUTER:
    AMD~SILVERSTONE~AUDIO CONTROL~BOHLENDER GRAEBENER~IMAGE DYNAMICS~ROCKFORD FOSGATE~OPTIMA~STINGER
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    Quote Originally Posted by blazinaspire
    amp
    sub
    each voice coil should have the same exact signal. i dont think that wireing each voice coil to it's own chan is recommended. if something happens you could end up ruining the sub
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    May 2006
    lancashire, england
    Exclamation audio system
    cheers for your ideas, the currency is pounds not euros over here, an i checked out the web address and its like 100euros for shipping!!
    my original ideas where for either 1 of these 2 packs from the website below, i found it to be quite cheap compared to others around here. check them out if possible and see which ones best. cheers
    http://www.caraudiodirect.co.uk/prod...oducts_id=4904
    http://www.caraudiodirect.co.uk/prod...oducts_id=4814
    _
    Mar 2004
    Little Elm, Texas
    blowchunks!
    hahaha
    go for it
    for that kind of a budget, just don't expect to get anything good.
    Id go with the Type S stuff from alpine before ANYTHING from blowchunks
    Jan Bennett
  1. Replies: 12
    Last Post: 10-24-2006, 03:34 PM
  2. FS: Award winning Car Audio system
    By RedGTiVR6 in forum Classified Archive
    Last Post: 09-01-2005, 08:37 AM
  3. Couple of questions about the monsoon system
    By Bugbyte in forum Car Audio
    Last Post: 07-07-2005, 08:47 PM
  4. Audio problems, Epia Sound, and FAQ stuff
    By gothate in forum Newbie
    Last Post: 06-16-2005, 05:04 PM
  5. Connect hand held MP3 player to car audio system?
    By jasonwood in forum General Hardware Discussion
    Last Post: 10-31-2001, 12:30 AM
