if i were you i'd go to some car audio forums and look through there stickies. maybe also be a little more clear on what you want too
so i have a 1999 mustang, the audio is ok but i want to put everything new in it just to give it some kick. i'm planning on a head unit a sub or 2 an amp and speakers to replace the stock ones, some r-blox, to damper the vibrtaion, and whatever else i need. i need help on installation and what exactly i need to get everything wokrking correctly. it has to be blaupunkt because i have connections through them, but i need advice on how to set everything up, and what exactly i need to make everything work correctly.
New System in progress:
M10k
Phaze TD1500 ~> Seas g18rnx/p
Zapco Ref 500.1 ~ 12" tc-9
Transflective Xenarc
My Car Pc Install
My Boat Pc worklog
Looking at a manul would also help alot, as that way you can work it all out![]()
[B]Car Computer 98%[|||||||||-]
Install Plan 100%[||||||||||]
Styling 20%[||--------]
Install 0%[----------]
well no, the thing is i'm telling you what i'm already getting, but i need to know how to wire the 2 subs to the amp to the ground to what ever power source i need, i'm also getting a capacitor, so i just need to know the basic way to put all of that together to make it work, what wires go where?
Amplifier Installation Guide: http://www.crutchfieldadvisor.com/S-...ion_guide.html
I'd honnestly get a buddy who has done this before to help you before you go delve off into the electrical system in your car.
Jan Bennett
