Results 1 to 10 of 12
Thread: Powering XM Direct for Laptop Setup?
    Apr 2006
    Is there a way to get this powered with the Laptop Carpc install? What connector should be used?
    Sincerely,
    t.
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Use the serial port on your laptop. It will work identically.
    Want to:
    Apr 2006
    Powering XMDIRECT with a laptop
    It is clear how to connect XMD1000 for control, I am wondering how to connect the power.
    Does the serial port provide power just like the USB?
    I thought i either needed to use some sort of 12v power source.
    Thanks,
    t.
    Maximum Bitrate pyros's Avatar
    Mar 2004
    Toronto, Canada
    You need a 12v power source which is indicated in the diagram in the tutorial. You can get this from an external source or from a molex connector from the power supply of the computer.
    2004 Ford Mustang Mach 1
    Specs: Epia M2-1000, 512mb ram, SB Audigy NX, Lilliput 7" Touchscreen, M2-ATX, DVD, 160gb HDD, gps, obdII, wifi, bluetooth, XM radio, HQCT and Logitech wireless gamepad.
    Install Status: DONE
    My XM FAQ
    Oct 2005
    Hou. TX
    What he means is, where can he get 12v from a laptop. You can't get it from the PSU and it doesn't have molex plugs. He will have to get a 12v source from somewhere in the car or a 12v battery pack.
    1999 Black Pontiac Trans Am
    CarPC's in F-bodies
    How To Relocate Climate Controls on the 97-02 F-body Cars
    (AMD Sempron 3000+, Opus 150)
    Car PC system is out, Alpine system is in.
    Apr 2006
    Jason,
    thanks for understanding. I though i was going a little crazy.
    Basically, I will need to run 12v power to the laptop in the trunk and I should find a way to run the same power to the XMD1000 in the dash?
    Does anyone know if there is a premade cord available that hacks XMD with the proper output? Or if it is best to buy a MOLEX-"Something" connector?
    Thanks a lot,
    t.
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Nooooo. You need to run 12v to the XMD1000. Why would your laptop need the power?
    Hint: your car operates on 12 volts of power. Try tapping off of a cigarette lighter, or the headunit power source to feed the XMD1000.
    Want to:
    Mar 2004
    Toronto, Canada
    I have a hacked up cigarette-lighter-type adaptor for mine. It actually lets you pick the voltage (ranges from 1.5 to 12), so I have mine set to 12. I didn't want to hook the XMD unit straight to the bbattery for fear of power spikes, etc. This adaptor has a built in fuse also.
    My suggestion is to find a cigarette lighter adaptor that provides 12v with atleast 300ma (mine is 500ma). Hack off the end and solder on a pos and neg wire to power it from a power source (mine is hooked up to a power distribution block).
    Do not over power the XMD unit, or you may fry it.
    My XM FAQ
    Apr 2006
    Thanks a lot man
    Thank you for the reply.
    Is there any way you could post some pictures of your setup?
    Thanks a lot.
    And also which cord did you use for power direct? the regular with the molex connector?
    Thanks a lot,
    t.
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Posts moved to clean XM FAQ thread.
    Want to:
  1. Wiring XM Direct internally to motherboard COM port... Having problems
    By sivart321 in forum General Hardware Discussion
    Last Post: 07-15-2005, 08:57 PM
  2. Sirius Tuner Like the XM Direct?
    By Geese in forum Car Audio
    Last Post: 12-07-2004, 01:46 AM
  3. XM Direct vs Pioneer's XM tuner??
    By mgithens in forum Car Audio
    Last Post: 12-07-2004, 01:36 AM
  4. Pictures of XM Direct box
    By SWC in forum General Hardware Discussion
    Last Post: 11-14-2004, 08:25 PM
  5. The plan, diagram of planned setup. VGA, GPS, XM Radio, Laptop.
    By rally1 in forum General Hardware Discussion
    Last Post: 11-25-2003, 07:13 PM
