Results 11 to 20 of 24
Thread: help choosing a capacitor for my system?
  1. #11
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    I've heard the 1 farrad per 1000watts rule of thumb before but I've also heard that they do little for your system. The capacitor arguement isn't something i'm willing to get into but, I've read that most times anything under say 15 farrads is a waste of your money.
    side note: I have a 1 farrad cap sitting in my room (got it for free with an amp i got) and have no plans on ever installing it.
    i'd also recommend going with an optima battery and upgrading the big 3 before considering the cap
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
  2. #12
    Maximum Bitrate Caelric's Avatar
    Sep 2005
    Bellevue, NE
    Caps are a band aid, when what is usually needed is major surgery. They do a good job of masking the real problem, but the real problem still exists and will bite you in the *** at some point.
    Oh, and yes, I do actually have a cap in my setup, it looks pretty cool, and has neat lights and a voltmeter. Thats about all it does, though.
    Dave
    2005 Infiniti G35 6MT Coupe Black/Black
    Core Duo CarPC
    CarDomain page
  3. #13
    _
    Mar 2004
    Little Elm, Texas
    heh - seems like most in here have already said it..caps are useless, UNLESS they are in the 3 farad + range
    else, it's nothing more than bling factor, at which point, those who know audio, look at it and feel sorry that you waisted your money
    spend your money upgrading the big 3 first.
    if you STILL want to go with a cap (at least you're looking in the right size range for one, unlike most posurs), the 5 farad cap should be enough, but if it's only a few $$ more, 20 won't hurt at all.
    one problem with caps is that sure, they provide power when needed, but then they have to recharge, granted it's lightning fast, but you're still down none-the-less
    for a 20 farad cap to fully discharge, you have to be doing some heavy lifting, and that MA amp isn't going to come close.
    Jan Bennett
  4. #14
    Maximum Bitrate Sidewalksalvage's Avatar
    Mar 2006
    NJ/RI
    So red, in your sistem, do you have any caps whatsoever?
    Im re thinking my set up....
    Brown 2010
  5. #15
    Constant Bitrate zzachattack2's Avatar
    Oct 2005
    Colorado
    Sorry if im "hijacking" this thread, but how does a 20F cap go for just a little more $$$ than 1F caps? Is it all just hype? (I know that 20F is better than 2F, but i mean in this context is the extra capacitance necessary?)
    One reason i suspect that is because from what I've seen, the higher quality companies don't manufacture huge zillion farad caps and stick to 1 or 2.
  6. #16
    _
    Mar 2004
    Little Elm, Texas
    Quote Originally Posted by Sidewalksalvage
    none
    in a properly built system (short of extreme situations - meaning 5000watts RMS or more) they aren't really necessary.
    beef up your power and ground wires to alternator, starter, and battery, beef up your alternator, and get a batter battery - will all do more, WAY more, than a cap
    Jan Bennett
  7. #17
    _
    Mar 2004
    Little Elm, Texas
    Quote Originally Posted by zzachattack2
    there are only a few manufacturers of caps in the world. Last I knew, only 3.
    and of course there's benefit to the extra capacatance, WAYYYYYY more benefit than 2 farad onone, which is pretty much worthless.
    you also need to remember that it's eBay, and there's a crap load of markup in car audio products.
    Jan Bennett
  8. #18
    Newbie iamfico's Avatar
    May 2006
    Pemberton, NJ
    http://www.rockfordfosgate.com/produ...0&locale=en_US
  9. #19
    May 2006
    Pemberton, NJ
    Meh so yeah, after reading everyone's posts I guess I'll try the whole "big 3" thing & maybe an optima yellowtop..... if needed I'll get the cap afterwards....
    thanks for all your help
  10. #20
    _
    Mar 2004
    Little Elm, Texas
    great decision!
    it's something you need to do anyways, if you still have issues afterwards, THEN consider a cap.
    Let us know how it turns out!
    Jan Bennett
  1. Ground audio system to battery??
    By eddie in forum Car Audio
    Last Post: 05-30-2006, 03:34 PM
  2. Is this a good car system?
    By lul77 in forum Newbie
    Last Post: 05-24-2005, 01:48 AM
  3. quick system disconnect idea
    By d_sellers1 in forum General Hardware Discussion
    Last Post: 05-14-2005, 11:35 AM
  4. FS: Carputer system w/o monitor (Boots in 15 sec)
    By Toups in forum Classified Archive
    Last Post: 04-01-2004, 12:01 PM
