Well, in theory you'd only need 2 farad for the subs. No real big point in putting a cap on everything else, just on the subs.
And you'd probably want a larger inverter.
I have most of the stuff I'll be using to setup my system & I'll be done pretty soon, but I was wondering whether a 5 farad capacitor would be enough or should I pay a few more bucks for a 20 farad oneIt will have a pretty decent sound system which would need a cap on its own but I just want to make sure the cap i get can handle the system and the PC
My setup:
P4 ATX PC w/400w power supply (uses about 300)
Xenarc in-dash touchscreen
2 JL 12W6 Subwoofers // powered by MA audio amp (500 rms to each@ 2 ohms)
JL 3 way component set & random rear speakers // powered by Alpine V12 (100 rms to each @ 4 ohms)
that pretty much covers it.... also these are the two i'm considering, if anyone has any other recommendations please let me know![]()
20 Farad Cap
5 Farad Cap
also... just thought i'd throw this in @ the end cuz its not really worth makin another thread but um... would it be safe to use a 400w inverter with the PC since it has a 400w power supply? even though the actual power usage of the PC is only about 300w?
cool... just out of curiosity though, how do you figure out how many farads you would need?Originally Posted by Jahntassa
also.... 1000w inverter sufficient?![]()
i think its better to avoid inverters. but if u want to use 1 id go like 500 just incase
If your willing to put a 20 farad cap, why not just upgrade your battery and keep the old one as a second, put it on an isolator and have two batteries? That will be far superior to the capacitors.
I have far less than his system and only a 1 farad cap (it was free) and it doesnt do jack in my setup.. I'm only 670RMS (per amp birthsheet 4Ohm x1 or 2Ohm x2) output by Sub amp.. and 1 50x4 (so like nothing) from the headunit.. I'd like to see where you'd got the idea for only 2 faradOriginally Posted by Jahntassa
Sell me your stuff.. please see what i'm looking to buy
http://mp3car.com/vbulletin/showthread.php?t=75182
Originally Posted by fooshizn1x
The general rule is 1 Farad per 1000w (peak) power you output to speakers or any high draw applicaton
The pc really isnt considered high draw, but subwoofer amplifiers are.
although a second battery will help the lenght of time you can run the system with the car off, it will not help reaction time of the subs. A capacitor will give you sharper cleaner bass and keep the power high on those continuous bass beats. A cap is used because the power can be pulled at a quicker speed than from the battery alone.
I run aproximatly 2000w on my subs and use a 2.0 farad capasitor, it works like a charm
5 Farad will probably be plenty of power, i think a 20 would be overkill.
Brown 2010
sidewalksalvage: Do you have any proof to backup what your saying? I'm not saying its wrong, I just dont believe it until I see something to back it up.
Normally the rule is 1 farad per 1000 watts RMS because amps never produce there rated peak power, its just a magical figure.Originally Posted by Sidewalksalvage
I would be looking to upgrade my battery to a deep cycle item like optima, also upgrade your ground wiring, alternator wiring and your power wiring depending on how large it is at the moment. That should be good enough to run all that.
If not simply add a second battery into your boot, i am running a dual battery system and it works perfectly. I am not a fan of caps, think they are more for wank/bling factor than anything else.
WEll i dotn really know how you want me to back it up....Originally Posted by fooshizn1x
Lol...i agree they are a bit of a "bling factor" but with my system, which contains an old battery and the original alternator...etc, the cap helps alot. See without it, when the bass hits hard, all my lights dim and the video screen flicks. With the cap installed however, everything remains at even power.
Is it necessary to have a cap...no, if you have a proper alternator and better end battery, you probably dont need it, but it cant hurt.
Brown 2010
well i hear that caps are **** from some people and from others i hear that they are great, but i have never used one, but i have my stock alt ( around 48A ) and i have a crappy battery in the engine bay and i dotn even have an issolator with my second battery ( energizer ) and my 550WRMS amp is hitting very very well, its all in your battery man, my energizer battery keeps my voltage at 13.9V and my amp is ratted at 14V at 550wrms at bridged 4ohms ( fosgate amp ) and everything is great, afcourse my voltage goes down a bit when the deep bass hits ( down to 13V ) but thats ok because everything int he car is run at 12V so at night my lights dont even dim, so my advice is get yourself a better battery and upgrade your alt power wire and your grounds, this alone without a second battery helps a lot
