Page 1 of 4 1234 LastLast
Results 1 to 10 of 35
Thread: i want to blow some speakers
    Sep 2005
    is there any way to blow speakers?? My friend bet me I could not blow my speaker with my amp... i want to prove him wrong!
    Aug 2004
    Nebraska
    There are a couple of things I can think of off the top of my head.
    1) Short the voice coil out by pushing too much current through the speaker, this also causes massive heat, which the speaker might not be able to dissapate properly. This is usually only do-able in subs since other speakers don't require as much power.
    2) the surround comes unglued or dust cap comes unglued. This is caused by pushing the speakers way too hard for an extended period of time.
    Now, unless your "friend" is willing to replace your blown speakers I wouldn't try this just for the hell of it.
    Also, if you try and push alot of current to your sub through your amp..make sure your wiring is up to par, or else you'll have a big mess.
    What are the specs on the things you are trying to blow up? Might help in determining if you can actually do this.
    2004 Nissan 350z Daytona Blue
    2x 10" IDMax D4
    1250.1 kicker amp
    crappy dell carputer
    Raw Wave Rob Withey's Avatar
    Apr 2000
    Bedfordshire, UK
    Rating of speaker? Rating of amp?
    To blow a speaker turn it up to number 11 (or more). You need to send enough juice to burn out the coil. DC offset is good, but most amps are capacitively coupled to avoid this.
    Sep 2005
    They are not subs, just regular speakers. They are alpines... i will look for the specs, but I think about 50w each @ 4ohms. My amp is about 45w@4ohms (after powering all four of my speakers). I already have new speakers, and one of these speakers has a hole in the rubber so I am not too worried about salvaging them.
    FLA gospeed.racer's Avatar
    Dec 2003
    Portland, OR
    Quote Originally Posted by Rob Withey
    LMFAO
    2005 Ford Focus ST
    Apr 2000
    Bedfordshire, UK
    Assuming the amp channels aren't already running in bridge configuration, bridge two channels and hook that up. Should increase your power output at the cost of less channels.
    Sep 2005
    Do you really think that will blow it? He says that the amp has some feature to protect against it or something...
    Aug 2004
    Nebraska
    the only way your gonna have a chance at blowing them is turn everything up to its max and let it loose. That will tell you if you can or can't.
    The amp doesn't know what speakers you are running or anything, it just see's the load and pushes current through accordingly.
    So, turn you amps gain all the way up, bass boost up, bridge your outputs, and connect it to one speaker. Then put on a nice bass beat, because low frequencies require much more current, and stand back and watch what happens.
    2x 10" IDMax D4
    1250.1 kicker amp
    Sep 2005
    I'm sort of a noob at all of this, so how do I bridge all the connetions to just one speaker? Do I simply line up all of the positives and negatives?
    _
    Mar 2004
    Little Elm, Texas
    Quote Originally Posted by fewman
    WTF!?
    are you expecting this to be some kind of incredible experience or something? some huge explosion?
    Jan Bennett
  1. Home speakers in the car
    By impulsenine in forum Car Audio
    Last Post: 11-23-2006, 03:57 AM
  2. soundcard + amp + factory speakers?
    By bmbr in forum Car Audio
    Last Post: 03-24-2006, 12:57 AM
  3. 92 range rover speakers cutting out
    By MAXXMODDER in forum Car Audio
    Last Post: 12-09-2005, 05:40 PM
  4. Rear speakers not going :(
    By samael in forum Car Audio
    Last Post: 08-13-2005, 03:33 AM
  5. Replies: 12
    Last Post: 10-28-2004, 07:44 PM
