many options
first is to take it back where you had it professionally installed and tell them it's not right
hi i have everything set up correctly i have two jl amps a sony head unit two l7 subs and i got it professionaly yinstalled my problem is that my front speakers the left one keeps distorting while th other one is clear and also my rear right speaker keeps cutting off and on randomly there seems to be no reason...so i think its due to the wiring of the speakers how can i do this
many options
Jan Bennett
c the thing is that i did not have them do that partt i had my speakers done a longggg time ago by soem one elses i want to do this on my own
ok - since i can't stand ebonics I'll let someone else take this one one
Jan Bennett
1. Check the wiring of your speakers.
2. It sounds like the front left one is blown, you'll probably need new speakers.
3. Your right rear one sounds like an amplifier, loose wire, or bad speaker problem.
4. Most of us speak English here, and asking questions in that language will help you get along better.
