Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: Amp has no power.. Help! Not Newbie.
    Feb 2006
    Hi everyone,
    I've hooked up many amps in my day This is my first carpc.
    Here are the specs:
    Mac Mini & xenarc screen off a carnetix 1900
    1 powered usb hub and usb hard drive powering off the carnetix 1290
    mitch's Sirius/alpine tuner
    Backup cam
    Gps
    Now the question. I had a cheap walmart amp powering the speakers. Worked for a month. The other day stopped working and went into protection.
    I'm stupid and bought a walmart sony 600w amp same thing... no power once I try to play music through it. Seems like it worked at first, then I started itunes and it died. I know I'm leaving the possibilities wide open. Just looking on where to start looking. Could i be drawing too much at once? The grounds appear to be fine. I'm getting 14v to the amp. and .5 @ the remote turn on.
    Any ideas will help a lot.
    Thanks!!!
    Jeff
    Newbie FrmDrkSide's Avatar
    Feb 2006
    California
    Well if it's not a typo, the .5 for remote turn on is your problem.
    Most amps will turn on with a minimum of 10.5v but 11v or more is the norm. I'm not sure if the psu unit your using has an amp turn on wire, or if your using it. But if it is only .5 volts on the turn on led, it definitely won't turn on.
    Disconnect the turn on from the amp and use a digital multimeter to read voltage, that would be a good place to start trouble shooting.
    Newbie blazinaspire's Avatar
    May 2006
    guelph otario canada
    yea and if you have nohthing to connect the remote wire to, then runa wire from the battery through a switch and then to the remote terminal, or just use your ignition wire
    Feb 2006
    hey,
    thanks for the help.. It's a typo... 11.5 on the remote
    Constant Bitrate mbuchman's Avatar
    Feb 2005
    Hm, well first thing to do is start at the amp.
    Check to make sure fuses are good
    If fuses are good, use a 1/8 to RCA converter plug so you can plug in a CD player or something directly to the amp. If no sound comes out, then it is a problem with the amp. If you find your amp working good, then you check to make sure the RCA line is good, and check to make sure that the carpc is putting out sound, and that the reciver is putting out sound, you get the idea. But start at the amp.
    Your amp might also go to protect if the gains are set wrong. But just start with the above, and keep cutting things out. Another good thing to do is pull the amp out, and put a different one in. If everything works, then you know it is the amp.
    Could also be blown speakers, but it isn't, so don't worry about that. But it is possible that the speaker wire shorted out or something, so if you have an ohm meter, you could measure the ohm level of the line. It should be anywhere between 1-8 ohms (cause you didnt say if it was a subwoofer or not), but if it is reading a really high or really low resistance, then you know the wire is damaged. really low resistance would mean that the amp would probably be going into protect due to the short.
    All those things are sorta scattered, but basically, you just start somewhere, and keep checking things off that work. You already did the power checklist, so that is a good start.
    -Matt
    _
    Mar 2004
    Little Elm, Texas
    ziljin - any luck?
    Jan Bennett
    Jun 2006
    Hamilton Ontario Canada
    so the turn on wire can go into any .5 wire? cause i have a stock head unit and dont have a spot to plug this wire in. any ideas?
    Jul 2001
    thebeebster: No, it cannot. In your car there will be a huge orange wire at the ignition harness, not the radio harness. Your car doesn't have an accessory power(switched) in the radio harness at all. Find the big orange wire (if you're colorblind ask someone to point the orange to you because the yellow stuff is the airbag). Tap it and put a 30A fuse on it and use that for your remote. The key will turn your amps on and off.
    Falls Church, VA
    Quote Originally Posted by Shadow
    30 amp fuse for remote turn on???? My god man, where are you getting your info from? Try .5 amp.
    And for others reading, not all cars use orange for acc. Please be careful
    Jul 2001
    Will, the 30A fuse is to protect in case of a dead short. If you put a .5A on it then you'll need to use a relay to power more than one piece of equipment. Otherwise you can just splice that one wire. 10 years of installation is where I get my info from.
  1. Newbie with power ?s for monitor
    By sengd001 in forum Newbie
    Last Post: 06-05-2006, 05:48 PM
  2. Cant get power to my amp...
    By Frankis in forum Car Audio
    Last Post: 03-26-2006, 02:17 PM
  3. car amp power supply
    By fuctup in forum Power Supplies
    Last Post: 11-03-2004, 02:52 PM
  4. cant get power to amp
    By Murphy3603 in forum Car Audio
    Last Post: 10-28-2004, 03:43 AM
  5. power? Subs w/ amp
    By Jeffro in forum Power Supplies
    Last Post: 10-31-2001, 12:50 PM
