Results 1 to 10 of 10
Thread: elemental designs subs
    Constant Bitrate studmonk3y's Avatar
    Feb 2004
    Honolulu, HI
    Hey everybody,
    So right now I have an infinity 7541a 4 channel amp running my 4 stock speakers. I'm thinking about disconnecting the rear speakers and adding a single 10" sub just to fill out the low end a bit better. So I'm planning disconnecting the rear speakers, bridging those 2 channels and running the sub off the amp I have now. I've been reading up on subs and wiring but I wanted to double check with you experts that I understand this right...
    My amp manual says bridged operation needs a min. speaker impedance of 4 ohms and my amp rating is:
    111w rms x 4 @4 ohms
    139w rms x 4 @2 ohms
    278w rms x 2 @4 ohms
    So i'm thinking of getting elemental design's 11kv.2 subwoofer http://edesignaudio.com/product.php?...onials&cur=USD and it comes in dual 2 ohm and dual 4 ohm varieties.
    So if I understand this correctly if I just want to run one of these subwoofers I should get the dual 2 ohm and wire it like this http://www.edesignaudio.com/site/wiring/1dvcseries.jpg ?
    Also anybody know the difference between elemental designs 11kv.2 and 11ov.2?
    Thanks for your help.
    _
    Mar 2004
    Little Elm, Texas
    am I missing the power specs on that sub somewhere?
    Jan Bennett
    Feb 2004
    Honolulu, HI
    weird wasn't listed on the first link i provided.
    http://edesignaudio.com/product.php?...pid=14&cur=USD
    250-500 watts rms
    _
    Mar 2004
    Little Elm, Texas
    provided that amp can handle a single channel bridged, I don't see a problem with it.
    Jan Bennett
    Low Bitrate Mandos's Avatar
    Sep 2005
    Coralville, IA
    Major differences between the Kv.2/Ov.2 series:
    The Ov.2's are more efficient(avg 1.1dB increase on same power) they have a higher power handling, more xmax, more motor, slightly flatter freq. response when a drop in replacement is made.
    That said...with the power you have available, 11Kv.2 D2 would be perfectly fine for you. And most amps work fine running 2 channels at 4 ohms each and the other 2 bridged to 4 ohms
    Red:
    http://www.edesignaudio.com/power.php
    Yay flash animations
    Chris Schempp
    Elemental Designs
    Scion tC in progress
    Feb 2004
    Honolulu, HI
    hey chris I didn't know you were a member of this forum. I've seen you around on scionlife.com. Are you gonna put a pc in your tc? thanks for the feedback guys
    Sep 2005
    Coralville, IA
    Quote Originally Posted by studmonk3y
    Eventually...more lurk and learn right now. Eclipse has upset me so I've decided to do it myself next time
    Chris Schempp
    Elemental Designs
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    are you aware of the group buy on the ED subs?
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    Feb 2004
    Honolulu, HI
    yea, I am, that's what prompted this post actually, thanks though
    Variable Bitrate jschrauwen's Avatar
    Jul 2006
    Frankford, Ontario, Canada
    Bringing out the dead here.
    Quote Originally Posted by studmonk3y View Post
    Linky doesn't work.
    Suggestions on how I should wire the eD e3.6?
    I'd like to know where I could buy the eD e3.6 as well.
    http://gickr.com/results4/anim_5055e...a2b3b197c9.gif
    1990 RHD JDM 300ZX TT 2+2 5sp T-Top
    491RWHP / 18psi / 94 octane
  1. Low-budget SPL Subs
    By SuprchargdMazda in forum Car Audio
    Last Post: 05-24-2006, 03:33 AM
  2. Soundblaster not pushing my subs...
    By 3onDubs in forum Car Audio
    Last Post: 11-21-2005, 05:27 AM
  3. Help hooking up subs and amp? Need advice...
    By jedi7001 in forum Car Audio
    Last Post: 05-17-2005, 02:28 AM
  4. Making Designs in Plexiglass
    By HHdesign in forum Fabrication
    Last Post: 03-28-2005, 10:50 AM
  5. FS: 2 mtx 10 inch subs and 400 watt amp with box
    By xdjxklusivex in forum Classified Archive
    Last Post: 02-25-2005, 04:41 AM
