Results 1 to 6 of 6
Thread: GM factory radio pin out for 2002 sonoma
    Mar 2005
    i put an aftermarket deck in a 2002 sonoma and was giving the old radio. Is it possible to hook a 12v ignition up to these radios since the harness does not have a 12v ign? I have the factory harness as well, but i don't know where an input for a 12v ign or the other pinouts would be.
    Qman
    FLAC Jahntassa's Avatar
    May 2005
    Conyers, GA
    As others will tell you, this isn't a car audio forum, it's for putting in CarPCs, and audio related to CarPCs.
    That out of the way, you'll have to find an ACC wire somewhere in the car to supply the ACC feed. Though you will probably be better off buying the correct adapter to work with the Class II Databus you have in the vehicle, and using the ACC that adapter generates.
    banned - scammer 97GST's Avatar
    Mar 2006
    Tijeras, NM
    Quote Originally Posted by Jahntassa
    MP3Car.com Forums > Mp3Car Technical > Car Audio
    His question is in the right area. And yes, you'll have to find the 12V input wires on the harness. It does have 12V input. Most likely Red, Yellow, Blue. Look for wire sizes if they changed it. Here in the next few days I could probably tell you which pin is the acc and 12V, since I just bought a harness for my friends 03 Sierra. This is the double din cd/tape/fm/am/xm stereo. I'm going to try and get ahold of it from him to put inside the eclipse temporarily.
    1998 Mitsubishi Eclipse GS-T
    ABIT NF-M2 nView | AMD Athlon64 FX62 Windsor | nVidia GeForce 6150 | Realtek ALC883 7.1DTS | Vista x64
    RF Power T162S | RF Power T162S | 2x RF Power T212D2 | RF Power T8004 | RF Power T20001bd | RF 3SIXTY.2
    Mar 2005
    Quote Originally Posted by 97GST
    Thank you very much 97GST, I would really appreciate the pinout.... i hope the install in the eclipse goes well, i could only guess how you would mount it in there, but good luck with that
    _
    Mar 2004
    Little Elm, Texas
    what he was getting at is: take it to a dedicated car audio form rather than a forum dedicated to CarPCs with a section for car audio AND your carpcs
    Jan Bennett
    Mar 2005
    here is what i have so far in the factory harness....
    B1 orange (i believe is constant)
    B2 drk green
    B3 empty
    B4 grey
    B5 black
    B6 empty
    B7 empty
    B8 drk brown
    B9 yellow
    B10 drk green
    B11 lt green
    B12 purple w/ white stripe
    A1 grey
    A2 empty
    A3 empty
    A4 empty
    A5 empty
    A6 empty
    A7 empty
    A8 tan
    A9 grey
    A10 lt blue
    A11 drk blue
    A12 black
  1. BMW E46 Owners with DSP systems and no HU
    By edrock200 in forum Newbie
    Last Post: 05-24-2012, 11:59 PM
  2. Class 2 Data Bus
    By owenjh in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 10-09-2008, 04:34 AM
  3. GM Factory AUX
    By Moneyfink in forum Car Audio
    Last Post: 03-15-2005, 12:40 PM
  4. Replies: 6
    Last Post: 04-02-2004, 04:01 PM
  5. WTB - Broken Factory Radio and HVAC Controls
    By e_z_street in forum Classified Archive
    Last Post: 03-11-2004, 07:45 PM
