Results 1 to 6 of 6
Thread: Lilliput indash motorized touchscreen monitor question
    Constant Bitrate mick0uziel's Avatar
    Feb 2005
    ca
    ok, i have the lilliput 701tv model, it has motorized indash touchscreen with built in radio and 45wattsx4 output. the problem is only the front speakers are working when i hooked it up. last night i even changed the wire harness and soldered them again. when i turn on the volume to high, then the rear speakers work but are scratchy. when the volume is low only the 2 front speakers work. i thought it was my stock wiring, but i put in my old deck, they all work fine. i put it on my 97 prelude which has a stock amp for the rear speakers ( i dont know why honda did this). any thoughts or suggestions? thanks
    7" Lilliput
    Opus 150
    mini itx 1Ghz
    1GB sdram
    97 Prelude
    FLAC Jahntassa's Avatar
    May 2005
    Conyers, GA
    Might be something to do with the stock amplifier? Maybe there's some wire you need to hook up to turn it on?
    _
    Mar 2004
    Little Elm, Texas
    either that or the outputs on the screen aren't all that great.
    the units aren't all that great in terms of build quality as far as I know, it's very possible that the connections are flaky.
    Jan Bennett
    Feb 2005
    ca
    when i connect my kenwood deck all the speakers works just fine ( i miss that sound really), so i know my current stock setup works ok. im not sure if the lilliput is not outputing enough coz when i turn up the volume that is when the rear speakers work but tooo loud at that point. i agree these lilliputs are not the best build. i got because i wanted an auto reverse camera and it has the built in output for the speakers. i should have went with the amp setup. help...
    7" Lilliput
    Opus 150
    mini itx 1Ghz
    1GB sdram
    97 Prelude
    _
    Mar 2004
    Little Elm, Texas
    ok - like I said, you need to check the rear outputs
    does jiggling the cables back there connected to those outputs make any difference?
    mind you, do it gently
    I would also consider contacting the vendor
    Jan Bennett
    Feb 2005
    ca
    hey red, how do i check the outputs in the rear speakers, i have a multitester, what do i need to check?voltage? what number am i aiming for? no tinkering the leads dont do nothing. thanks
    7" Lilliput
    Opus 150
    mini itx 1Ghz
    1GB sdram
    97 Prelude
  1. Lilliput touchscreen motorized VGA screen audio problem
    By mick0uziel in forum LCD/Display
    Last Post: 07-11-2006, 11:51 AM
  2. WTB: 6.5" - 7" Motorized In-Dash DIN Style Touchscreen Monitor
    By n33d45p33d in forum Classified Archive
    Last Post: 05-01-2006, 11:17 AM
  3. *****ing lilliput touchscreen
    By mrzigzag in forum LCD/Display
    Last Post: 04-13-2004, 03:31 PM
