Results 1 to 10 of 15
Thread: Onboard sound crackling DC-DC
    Variable Bitrate Philhop's Avatar
    Apr 2006
    Hi , I have a problem that im getting weird sounds using onboard sound on my epia 13000 causing cracklng and whininy noise car is stationary , any ideas? im using a dc-dc psu will a external sounds card solve this , also I still get a thump with a m1-atx
    _
    Mar 2004
    Little Elm, Texas
    do you know what alternator whine is? or engine noise?
    does it sound like any of these?
    are you running aftermarket amplifiers? are you running the stock sound system?
    having all of this information is kind of critical to being able to help you out here.
    Jan Bennett
    Apr 2006
    Quote Originally Posted by Red GTi VR6
    I know what they sound like it isnt alternator whine , as the car is off or engine noise , i think it might be a bad ground for the computer so i might try another ground after my m1 is fixed
    Many thanks
    _
    Mar 2004
    Little Elm, Texas
    please let us know if grounding the PC helps at all.
    good luck!
    Jan Bennett
    Apr 2006
    1et you know in 3 days
    _
    Mar 2004
    Little Elm, Texas
    3 days?
    why so long? we can't wait that long!
    hehe
    Jan Bennett
    Apr 2006
    MY M1-atx Blew up waiting for a replacement hold on!
    Haha
    FLAC ppgt94's Avatar
    May 2001
    USA
    You may already know this but I'll offer some tips, just in case. Make sure to get a good metal-metal connection. So sand down any paint at the grounding point and I recommend the use of star washers, too. Use the same guage wire as you did for your 12v+ and keep it under 16" in length.
    I had a problem with weird noises, clicks, hdd/cd-rom spinning, etc through the speakers for a long time. Finally last week I added a good ground to my case (near the sound card - not sure if this makes a difference or not) and I'm amazed at how clean the sound is now.
    Let us know how it goes.
    Apr 2006
    Thanks for that tip , Im going to screw the case through the floor in the car so that should ground it and then the negitive wire im going under the front seat with the tips that you said
    Unregistered User ODYSSEY's Avatar
    Feb 2001
    Raleigh, NC USA CarPC Ver3: [▓▒▒
    Have you tried muting different audio sources?
    ODYSSEY
    Quote Originally Posted by Tidder View Post
    Digital-Car UK|
    (\__/)
    (")_(")
  1. FS: USB Sound Blast Live 24 bit & Pioneer 4 Channel 300watt amp
    By clean customs in forum Classified Archive
    Last Post: 05-21-2005, 11:04 AM
  2. Need advice on which sound card to use
    By mtmsol in forum General Hardware Discussion
    Last Post: 06-22-2001, 01:39 PM
  3. hotdeal on microatx motherboard that come with sound and video onboard
    By noproblem in forum General Hardware Discussion
    Last Post: 07-06-2000, 04:26 PM
  4. 9.5" LCD from allelec.com & motherboard w/ onboard sound
    By mjohnson in forum General Hardware Discussion
    Last Post: 03-05-2000, 07:36 AM
  5. New sound cards w/ onboard decoding
    By alecl in forum General Hardware Discussion
    Last Post: 10-06-1999, 06:27 PM
