Results 1 to 9 of 9
Thread: ford 6000cd radio with intergrated bluetooth?
    Feb 2005
    Hi there wondering if anyone can help. I am trying to fit a bluetooth kit to my ford focus with a 6000CD radio. I am tryin to get the sound to come out of the car speakers. But am not sure how to go about doing it. Can any1 offer any advice. If you are not sure about this particular bluetooth kit I dont mind getting another one if you know how to intergate that 1.
    Thanks Alot.
    Elsewhere
    I deleted your crosspost. There is no need to crosspost questions here.
    As to your question, I don't think these forums are your best solution for an answer, as our focus is on installing computers in vehicles. It's possible you might get lucky and someone will have an answer for you, though.
    Good luck.
    How about the Wiki?
    Falls Church, VA
    Quote Originally Posted by mdray00
    Thanks Alot.
    Your options are no different than hooking up a car puter. You can use a FM modulator to get the sound through the FM or search for an aux input interface that connects to the CD player BUS. Both of these will require you to tune to a specific station or hit a button to get the Bluetooth device's audio through your stereo.
    You will NOT be able to have the radio/cd/xm AND the bluetooth play at the same time.
    Elsewhere
    Aren't there cellphone adapters that mute the stereo volume when a call comes in or you place a call? I know I've seen wired ones that have this capability, but I dont' know about bluetooth.
    How about the Wiki?
    _
    Mar 2004
    Little Elm, Texas
    you are correct Darque - there are wired ones, they are usually part of hands free kits.
    being that I haven't kept up with the blue tooth technology, I'm not sure on those though.
    Jan Bennett
    Falls Church, VA
    BUT the stereo must have an input for that wire to work. A lot of mid to high level decks had a phone mute wire but i have no idea if the factory ford does.
    _
    Mar 2004
    Little Elm, Texas
    true - if I get a chance, I'll call a friend today and see if he can help out
    Jan Bennett
    FLAC Jahntassa's Avatar
    May 2005
    Conyers, GA
    What Will Albers said is true. My Motorola BT kit comes with a 'mute output', but the factory radio has to have that 'phone mute' input. It -might- have it, but the poster is gonna have to really search to find the info on it.
    Newbie bentou's Avatar
    Jul 2006
    near Paris / France
    There is several models for the 6000CD.
    If yours looks like http://www.forum-auto.com/uploads/20...33436_71_1.jpg (available in silver or black) you can find the wiring on
    http://www.hearsay.demon.co.uk/puma/audio.html or
    http://www.david.lanham.btinternet.c...dio_wiring.htm
    When the mute is active, the LCD displays "Phone"
    As I don't have any bluetooth kit, I could'nt try it ...
    Do you think that I could use both my phone and my PDA with Tomtom with one bluetooth receiver ?
    HTH,
    Ben.
  1. Class 2 Data Bus
    By owenjh in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 10-09-2008, 04:34 AM
  2. TM-701L converted Lilliput causes radio interference
    By archimense in forum LCD/Display
    Last Post: 07-04-2004, 09:14 AM
  3. Fm Radio
    By vicky_obee in forum Media Engine
    Last Post: 07-01-2004, 11:52 PM
  4. How do i make Radio working in MediaCar?
    By zvi in forum MediaCar
    Last Post: 05-16-2004, 03:38 PM
  5. FM radio Question
    By thepogcbr900rr in forum General Hardware Discussion
    Last Post: 05-09-2004, 07:27 PM
