Page 2 of 6 FirstFirst 123456 LastLast
Results 11 to 20 of 55
Thread: Car audio question - 2003 Audi A4 - how to power it?
  1. #11
    Mar 2006
    San Diego, CA
    @Will Albers - so I can get an adapter that will allow me to hook into my factory amp? Is it really that easy? I would love if that were the case...
    Edit: I found this item. Will this allow me to take RCA audio from my soundcard and simply plug into my factory amp and speaker setup? http://www.cardomain.com/item/PERSVEN4?vq_id=none
    It says this:
    Typical Applications
    Aftermarket Receiver to Factory Amplified System
    (such as Premium, Infinty/JBL, Mach, Bose systems)
    So, aftermarket receiver = pc soundcard?
    ~Puff
    View my worklog... I dare you... http://www.mp3car.com/vbulletin/worklogs/77267-2003-audi-a4-worklog-puffs-ride.html
    Carputer Progress [||------------------] 10%
  2. #12
    _
    Mar 2004
    Little Elm, Texas
    Quote Originally Posted by DJiK
    Red,
    In my post, I never said I was running stock 6x9"s and 6"s.
    As a matter of fact, what I had planned out and later shared above was never meant to be for factory speakers.
    So in a way I'm glad you're agreeing with me.
    Sorry - I was speaking to Puff.
    Jan Bennett
  3. #13
    Newbie Paul H's Avatar
    Apr 2005
    Breda, The Netherlands
    audio layout
    Quote Originally Posted by Puffanug
    Are there any websites that show the factory layout of my system? Like something that shows how many speakers, how many amps, and how they are wired? I count 8 speaker grills (2 front center dash, 2 front door (each door), 2 rear door (each door), and 2 maybe 4 on the rear deck).
    @Red - Could you make any suggestions for my setup? If I were to rip it all out, what would I need to replace it with? I'd like to keep the cost low, but get decent sound. I would prefer to keep the speakers, but i am looking at all options right now...
    P.S. Thanks to everyone for the replies...
    P.P.S. I can get good deals on Sony car audio stuff, but I have heard they aren't that great. Any opinions on Sony amps or speakers? Thanks again!
    If you PM me your VIN-number I can post the scheme of the OEM audio which is in your vihicle.
    Paul Huijgens
    Audi technician
    former Saab technician
    Mp3Car.com Forum
    SaabCentral forum
    Dutch Carputer forum
    Navplus forum
  4. #14
    Jun 2006
    toledo, oh
    any way i could get that scheme too? i have the same car and having the same problem figuring out what to do. that would help a ton!
  5. #15
    Falls Church, VA
    It says this:
    You got it... Thats all you need
  6. #16
    Mar 2006
    San Diego, CA
    @Will Albers - that's good news. Another user brought up a point though. Since that adapter is for aftermarket HU to factory amp & speakers, will the signal from my soundcard be powerful enough? Logic is that aftermarket HUs are powered...
    ~Puff
    View my worklog... I dare you... http://www.mp3car.com/vbulletin/showthread.php?t=77267
  7. #17
    Mar 2006
    San Diego, CA
    I emailed this to the manufacturer of the SVEN4...
    I would like to know if the SVEN4 would allow me to connect a RCA output from a non-powered device (a computer soundcard in this case) to my OEM speakers and amps. I have a 2003 Audi A4 with the Symphony (non-Bose) double din headunit. I will be removing the headunit and replacing it with a touchscreen lcd in the dash and a computer to provide the audio. I do not want to replace the factory speakers or amp, and am hoping the SVEN4 will bridge the gap between my computer and factory speakers/amp. Thank you.
    We'll see what they say...
    ~Puff
  8. #18
    Falls Church, VA
    A decent sound card will provide enough juice to work fine. I'd bet the adapter can handle .5 volts all the way up to 5+.
    Get the adapter...
  9. #19
    Jun 2004
    Rochester
    Here is the wiring diagram for your 2003 Audi A4 1.8t.
    2003_Audi_A4_1.8t_radio_amplified_notBose.pdf
    It should be noted that there were 3 different sound systems available for the sedan: 1) Regular system without an amplifier. 2) 10 Speaker amplified system. 3) The Bose system.
    From the information you gave, I believe you have the 2nd system: amplified, but not Bose.
    The factory amplifier is for the 4 rear speakers (2 on the left, 2 on the right) as well as the factory subwoofer. The 5 front speakers (2 on the left, 2 on the right, 1 in the center) are powered directly off the head unit.
    It should be relatively easy to figure out the wiring for the factory amplifier using this diagram and a multimeter. (Just guessing i would say pins 1,2,3 are the line-level audio input signals, probably left,ground,right. Pin 9 looks like the amp turn-on signal. 14-21 are outputs to the speakers. And 22 and 23 appear to be Ground and Power.
    For the front speakers you will need an additional amplifier. Crossovers are not necessary as they are built-in already. A 2 channel amp will suffice if you forget about the center speaker. If you want to use the center speaker you may need to go to a 4 channel amp.
    I hope this helps - Good Luck.
  10. #20
    Mar 2006
    San Diego, CA
    @Walky talky20 - thank you for clarifying that. I do believe I have the 10 speaker with amp package. I am working on a diagram to show how this is all going be wired up. The attachment you posted is invalid though when I click on it. How big is the attachment? Maybe you could email it me... pm for the address... thanks again.
    ~Puff
  1. Car power supply (battery charger) from old pc supply
    By stimps in forum Power Supplies
    Last Post: 08-20-2010, 12:39 AM
  2. SDPIF digital Coax into car audio pieces
    By RedGTiVR6 in forum Car Audio
    Last Post: 10-14-2008, 12:06 AM
  3. power problems while car is running..
    By TimW in forum General Hardware Discussion
    Last Post: 03-18-2006, 09:11 PM
  4. '98 Corvette Indy Pace Car-Puter
    By fredp in forum Show off your project
    Last Post: 10-05-2005, 10:09 AM
  5. A few observations in OS and why I'm now using Windows 2003...
    By Mastiff in forum Software & Software Development
    Last Post: 01-21-2004, 09:11 AM
